05-06-2012, 02:07 AM | #16 |
If you cut the chain too short, you could use two master links. It's not ideal, but I sure would if I paid good money for an o-ring chain.
05-06-2012, 05:47 AM | #17 |
pliskin, i m still on the original chain, just keeping it well greased.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
05-06-2012, 06:09 AM | #18 | ||||
I wasn't planning on getting a chain-braker but maybe i'll have to rethink that as well. Quote:
Do you hit the pin with something after you grind the tip, so it comes out? I should also check some youtube videos.
Zongshen 200gy-2 |
05-06-2012, 09:00 AM | #19 |
Just my $.02 on chain breakers. I have never owned won, and unfortunately I only put on a small fraction of the mileage that Spud does, and rarely need to remove links from a chain.
When I do need to shorten a chain, I just completely remove the head on the pin where i want to break the chain with an angle grinder, and tap out the pin w/ a punch...or a framing nail if i can't find my punch :oops: Either way, you can get chainbreaker and do it like the pros and Spud, or use a grinder, a hammer and a punch like me and the redneck hillbillies. You're in luck pliskin...this guy working without a chainbreaker speaks Aussie as well...I think |
05-06-2012, 12:54 PM | #20 |
I do it exactly like wilserchinarider; they key word is "tap" the pin out. There will be no force required once the peened portion of the pin is ground away. They literally fall apart at that point. Just take care to not grind on a link that you need to keep.
If you're at all concerned about grinding too far, you can just grind a little, so as to remove the hardness layer. You can then use a very sharp file to work the reast of the peened portion away. Even if you get a chain breaker, you need to grind the pin. You definitely don't want to force the peened portion through the cylinder on a brand new chain.
05-06-2012, 03:17 PM | #21 | |
If that gentleman wanted to remove two links, he cut the chain too short. He actually removed four links from his drive chain. Why was he wearing a ski mask? :?: I wouldn't do this job in my bathroom, either. Spud
05-06-2012, 03:46 PM | #22 | ||
I must admit, I have never tapped the pin out of a drive chain I have shortened. Brother Andy offered to shorten my first drive chain at the diesel repair shop he supervises. He ground the pin in a large vise. Then he had to punch the pin pretty hard to remove it. Perhaps the heat from his grinder welded the pin slightly to the link. :? I didn't have access to a vise when I decided to break my next chain. Therefore, the next time I needed to shorten a drive chain, I got a heavy-duty chain breaker on sale from Harbor Freight, which was located about one mile away from my home. I've been using the chain breaker ever since. http://www.harborfreight.com/heavy-d...ker-66488.html Quote:
05-07-2012, 12:59 AM | #23 | |
If Andy had to apply force to tap the pin out, then the peened end of the pin wasn't completely ground off. When the chain is constructed, the pin is placed in the bore, and then the ends are mushroomed, or peened. I grind the pins intentionally; I don't want any of the mushroomed material to be forced through the bore, in case it should be damaged in the process. I's a delicate dance though, because it's very easy to grind too far. I have.
05-07-2012, 12:31 PM | #24 |
This guy removes and adds links with just a hammer and punch, no grinder. 8O Notice in the vid how his thumb is injured. This guy is a graduate from "The School of the Bigger Hammer"
What really surprised me is that he reuses the link??? |
05-07-2012, 02:41 PM | #25 |
I guess real men "don't need no stinkin' grinder!"
I really enjoy the convenience and easy application of my chain breaker. They really don't cost very much. Spud
05-07-2012, 02:46 PM | #26 |
You can also carry a chain breaker with you in your tool kit while traveling on your motorcycle. The chain breaker is more portable, and weighs less than a vise. Also, I would trust my chain repair much more after using a chain breaker, rather than a big hammer!
05-10-2012, 02:16 PM | #27 |
Did you decided which drive chain you are going to buy? Please give us an update, Pliskin.
05-10-2012, 08:22 PM | #28 | |
Thinking back when I changed rear sprockets on my boy's chinabike, I left the chain on the bike, put the oversized chain on the rear sprocket and did surgery to the chain with the grinder on the bike...not saying this is better, but it is fast and dirty keeping w/ the china bike motif... I'm sure the chain breaker is a nice tool to have in your arsenal and is surely more professional, the thing I like about chinabikes is that repairs can usually done be w/ a couple of crecsent wrenches and a "big hammer" |
05-11-2012, 01:30 AM | #29 |
The detail I failed to share before is that I use a flap disc on a 4 1/2" grinder for good control, not a grinding disc.
05-11-2012, 03:45 AM | #30 | ||
Thank you wilserchinarider for youtube link. I've checked few now they are very helpful.
Thank you Weldangrind for further explaining the procedure. We'll have to go through this post again when i have to do it. Quote:
Before deciding for KMC i tried 2 local bike shops. But with no luck. I wanted to settle even for standard chain but they didn't have the length that i required. So last night the link you gave me of KMC chain on ebay, that's the one i purchased. So now i am waiting for it to arrive. It should take between 7 - 35 days.
Zongshen 200gy-2 |
