05-16-2020, 01:48 PM | #16 |
Also, bog only happens at > 1/4 throttle. Comes cleanly off idle with the needle in the lowest position but after 1/4 throttle just lean bogs. Maybe I need a richer needle taper or larger main?
05-16-2020, 02:10 PM | #17 |
With the airscrew all the way in the bog doesn't seems to be as bad, so I assume larger pilot or greater needle taper?
05-16-2020, 04:28 PM | #18 |
If you're using the 17.5, and the air screw is almost all the way IN, you need to go to a #20 or a #22.5 pilot jet, and reset the air screw to 1.5 turns OUT, and then fine tune from there.
09-10-2020, 01:50 PM | #19 | |
08-12-2021, 03:52 AM | #20 | |
