09-12-2014, 10:58 AM | #1 | |
09-12-2014, 11:09 AM | #2 |
kill wire
Before you remove the kill wire on the cdi.... just hook your test light to the POSITIVE on the battery and touch the middle wire on the row with 3 wires..( on a single plug cdi )... if the test light lights up... something is grounding the spark.... and then remove the wire from the cdi... if should then start... but not shut off... this is the easy for sure way to test.... if it does not give spark then.... go and check spark coil with ohm meter,,,,, sometimes there is no continuity from the coil input to the end of the sparkplug wire( where the sparkplug fits ).... this is a bad plug end.. there should be a sticky on this no spark problem.. because this is the most common problem
09-11-2014, 10:37 PM | #3 |
Typical horizontal chonda http://do.ejdz.cn:8087/%E6%91%A9%E6%...F%E5%9B%BE.gif
Welcome to electrics literature club. There's a Cantonese saying about Qs 唔識就嚇死,識就笑死 [The ignorant are scared to death ,the well informed just laugh to death ].
