01-08-2007, 06:06 PM | #16 | |
01-08-2007, 06:41 PM | #17 |
My Roketa DB07a (RSX200E) DOES have the OHC motor. It came with 14/45 (or 46?) sprockets. Cruises at 50 easily with plenty of throttle (but not a lot of power) left. Wind resistance becomes an issue before lack of engine speed does with the correct gearing.
01-08-2007, 07:03 PM | #18 | |
01-08-2007, 07:19 PM | #19 |
Yes, use the Lifan GY-5 as the standard; 17 t front, 46 t rear gets those owners to 65 mph stock, 70 in a pinch...if you already have a 17 t front, you are half way there!!
01-08-2007, 10:00 PM | #20 | ||
i'll be sure to post back how it runs with the 17/42 combo. |
01-09-2007, 01:10 PM | #21 |
Hey Bruce and RPM, I went each of your websites. I hadn't really considered the Lifans but I think I will now. Good looking Bikes! By the way what is the seat height for those? I've seen conflicting reports. Also on the website they show drum rear brakes but I saw some on ebay with rear disk?
01-09-2007, 01:19 PM | #22 |
The Rokets DB07A (RSX200E) IS the OHC motor. The manual does show pushrods, but there aren't any. The manual is about as accurate as the assembly instructions were, NOT!
01-09-2007, 06:00 PM | #23 |
Spanks100,
Thanks for visiting the site and for considering the Lifan bikes. The seat height is about 33" on the GY-5 and 32" on the GY-2 model when no weight is on it. They stand a little tall for some folks, but have plenty of travel. Some minor adjustments can be made to relieve some stiffness. They will soften a bit in time, the old saying ... the more you ride, the better it runs. Both bikes, GY-2 and the GY-5, have the inverted front shocks now and disc brakes on front and back. I never ordered any of the GY-2 bikes last year, but I believe they came with drum rear brakes and conventional shocks according to the information I got, but maybe Bruce can answer this better as he was carrying all models. These are available now pretty much the same other than plastic, different exhaust, different seat and a covered tank for the GY-2 model. If you want to get more specs, I have them from the handouts that I get from Lifan posted in my gallery on this forum. Hope this helps!
RPM - REV IT UP! (REDLINE is OPTIONAL) Feel the RUSH ... it gets better all the time! |
01-11-2007, 04:25 PM | #24 |
Hi!
Just wanted to let you know my experience with changing the sprockets. My Loncin lx200 came with 14/42 sprockets. It could barely reach 90 km/h (50 mph I think). So I changed the front sprocket to a 17 toothed one. Then I could ride it with max speed of 120km/h ! HUGE change! I have also changed the rear sprocket to 40 now. With the 17/40 configuration it will go just under 130km/h. 8) Cruising speed is 90-100 km/h. The disadvantage is that I need to rev the engine quite a bit when I start from a standstill, or else the engine will stall. So 17/40 is an absolute maximum gearing, IMO. I need this for a lot of highway riding, and I just hate when the engine is screaming for mercy :wink: |
01-11-2007, 10:58 PM | #25 |
i just switched my sprocket today to my 42 tooth. it rides pretty good. i think it's a bit much and i proved that tonight trying to climb a hill and stalling out. it will probly go excess of 70 mph. i have no idea cause my speedo cable is broken. i think the 46 rear would be the best. i might put a 16 front on it now.
01-12-2007, 02:33 AM | #26 |
Sounds good, thanks for the review!
01-12-2007, 07:24 PM | #27 |
I have tried the 17/46, 17/42 and 17/40. I settled on the 17/42 as the best (for me) combo I have been recomending to folks that want a 70/30 or so street and trail ride. It will run a top speed (level ground) of 74 mph per Garmin gps.
Joe |
01-12-2007, 08:31 PM | #28 |
that's excelent. i have my 17/42 now and i think i'll be trying a 16 tooth front just to see what it's like. that should be more like a 17/45. i miss the trails a bit. i need to get my speedo working as well.
01-12-2007, 08:35 PM | #29 |
Mule,
Is that with the OHC engine? Jason
01-13-2007, 09:21 AM | #30 |
FMYStreetRacer
Send me a pic of your speedometer cable with the entire length. I have GY-2 & GY-5 cables in stock. Ride Wild and Fly Like an Eagle! 8O Bruce
