Old 12-25-2014, 11:15 PM   #16
Remove the flywheel bolt, and check the female thread. Is it left hand or right hand? I'm not talking about the bolt that secures the flywheel, but rather the large internal female thread that will be revealed after the bolt is removed.
Old 12-26-2014, 08:34 AM   #17
TheGageinator   TheGageinator is offline
i didnt think about it maybe being left hand threads... il check that tonight. i have 2 large tap and die sets, and neither of them had the tools that would match up so i could identify the threads... i think it may be 18 threads per inch. i keep seeing a ton of tools for a gy6. i dont know why its so hard to find one for this zong 197cc engine
Old 12-26-2014, 12:39 PM   #18
It's because there were a few different styles. BTW, it will be metric, not SAE thread.
If it is right hand thread, you'll be able to buy a bolt that will screw in, which you can use to pop the flywheel off. Easy, fast and cheap. Rarely are those three words used to describe the same thing.
Old 12-27-2014, 08:19 AM   #19
haha it would be nice if i get to use those words on this job. i checked, and I have right hand threads. i need to find a bolt now. will update
Old 12-27-2014, 02:27 PM   #20
Fastenal is a good source.
Old 12-28-2014, 12:19 AM   #21
I got it! You were right! I just used a metric bolt and impacted in! The flywheel popped right off. I'll post the thread pattern when I find out what it is. I got lucky and just found a bolt that worked.
I did notice that my starter clutch was broken. That's where my starting problem was coming from. The Sprag Clutch came loose from the gear. I have ordered a new one for $38 on eBay. I also ordered all new seals and o-rings
Starter clutch
http://pages.ebay.com/link/?nav=item...633894&alt=web
Shifter seal
http://pages.ebay.com/link/?nav=item...018066&alt=web
Crankshaft seal behind starter clutch
http://pages.ebay.com/link/?nav=item...390929&alt=web
Complete engine gasket set
http://pages.ebay.com/link/?nav=item...113143&alt=web
The clutch and gear are supposed to be one piece.....
Flywheel scared from clutch going bad
Old 12-31-2014, 11:48 AM   #22
Glad to hear you were able to remove the flywheel for cheap. The price on the replacement parts isn't too bad.
Please post a follow-up as you begin repairs.
Old 01-05-2015, 09:38 PM   #23
Got the starter clutch changed out! I also changed all the seals and O-rings in the process.
Starts up like a champ
everything went back together well, but the shifter seal is still dripping oil when not driving. slow drip.
Old 01-05-2015, 09:41 PM   #24
Got some goods installed today! ProTaper pillow-top grips and some cheap hand gaurds.
Old 01-05-2015, 09:51 PM   #25
when working on my atv, i lifted it up to place it on jack stands. I noticed that driver (left) side front wheel was closer to the ground..... the passenger(right) side was higher. after some investigating, i found that the driver(left) side upper a-arm mounts were welded too low on the frame... great.
i adjusted the passenger side lower shock mount to match the offset. now its level.... ill have to get the plasma cutter out and re-weld the mounts later.
right side ok
left side bracket welded too low on the frame tubing
Old 01-05-2015, 09:53 PM   #26
Banshee shocks!
I found some Yamaha banshee front shocks that are the exact same length as the stock ones! i held them in place, and noticed that the mounts will need to be widened. I tried putting one on the back, but it was WAY too soft. im thinking they will be perfect up front.
they are 15inches from eye to eye
Old 01-05-2015, 10:41 PM   #27
Put some tusk headlight bulbs in today! I'll take a picture at night when I get a chance. They are 35watts. Stock ones were 18watts
http://pages.ebay.com/link/?nav=item...281697&alt=web
Old 01-06-2015, 12:45 AM   #28
Not at all surprised to see the control arms at different heights.
Good call on the Banshee shocks! I wondered if those would work, since my quad is so closely patterned after a Banshee.
That headlight might be a bit much for your stator. Beware dead batteries.
Old 01-10-2015, 11:33 AM   #29
i stretched my shifter lever 2 inches today. i could shift ok with shoes on, but not with boots. woohoo .
Old 01-12-2015, 12:08 PM   #30
Nice work.
