Old 07-24-2007, 08:26 AM   #16
katoranger's Avatar
I think I am going to try it on my pushrod motor on Wednesday. I will take some pictures to add to this sticky. I is going to involve dropping the motor out and I also plan to do the engine bolt upgrade at the same time plus check things over good while the bike is apart.
Allen
Old 07-25-2007, 12:01 PM   #17
katoranger's Avatar
Is .05 mm (slightly under .002") correct for the pushrod engine for both valves I found this by searching for specs.
Jetmoto says to adjust to .004" intake and .006" exhaust.
Allen
Old 07-25-2007, 08:30 PM   #18
Beavis   Beavis is offline
.004" and .006" will be so noisy, you will need earplugs! 8O Use 0.05mm (.002") and 0.08mm (.003") as suggested, and you will be much happier.
<div>Pain is temporary, bones heal, chicks dig scars, thrill is forever.</div><br />
Old 07-25-2007, 09:09 PM   #19
katoranger's Avatar
Good thing I haven't gotton it all back together yet. I set them to .005". Will change it tommorrow. That seems to be about what they were at before I started.
Allen
Old 07-26-2007, 07:00 AM   #20
Just did mine the other day. Not careful on the first time, and very unhappy that I had to pull it all apart to do it again. :evil:
For me, I did not have to pull the motor all the way out, I left the lower most rear bolt in but loose, so I could just pivot the motor down and then back up. It's much easier if you don't have to wrestle with it. Good luck.
Old 07-26-2007, 03:59 PM   #21
katoranger's Avatar
I went back and set them .05mm. I think that is about what they were before I started. I am thinking that I may be able to get the valve cover off without lowering the engine. I will have to try it next time.
Allen
Old 09-07-2007, 01:54 PM   #22
madmanjustice   madmanjustice is offline
hmmmm... i picked up 2 sets of feeler gauges today and niether one of them go down to .05mm. In fact none of the sets that I was looking at went that small if i remember correctly.
where are you guys getting your feeler gauges.
2005 Roketa rat bike - The Ratketa
1982 Yamaha Maxim 750
The Ratketa Restoration Project
The Ratketa Blog
Old 09-07-2007, 03:38 PM   #23
katoranger's Avatar
Grandpa's toolbox.
Allen
Old 01-12-2008, 05:30 PM   #24
Q   Q is offline
Tips for the OHV engine
Many of the LF200-GY5 bikes do not have enough clearance between the engine and frame to remove the valve cover. It's a pain to remove the engine mounting bolts and lower the engine. I found that if you grind off about 1/8" of one of the ribs on the valve cover it will clear the frame.
I used a Dremel tool with a sanding drum to remove the material while the valve cover was bolted to the engine. Here's a pic showing which rib to grind down. The rib is already ground down in this pic.
This is a closer pic of the valve cover with the rib ground down.
Here is the rocker assembly on the OHV engine.
This shows timing mark and flywheel bolt access.
Close up of the TDC mark "T"
The bolt used to turn the flywheel to align the timing marks.
Q
Old 01-14-2008, 11:56 AM   #25
katoranger's Avatar
Q, I had thought of doing the same. You can almost sneak it out with the motor bolted in so it had me thinking that just alittle grinding would make it clear.
Thanks for the pics.
Allen
Old 01-29-2008, 08:20 PM   #26
Guest
Posts: n/a
thanks Q.
Old 02-05-2008, 08:22 PM   #27
Hondarider27   Hondarider27 is offline
This helped alot. Would i want to line up the T or the line right next to the T with the line on the case. Also should i use the .002 intake and .003 exhaust ajustments for my star 200cc atv? Thanks alot
Old 02-05-2008, 08:33 PM   #28
Q   Q is offline
Yes, line up the line right next to the T although it's not critical. Sorry I don't know the recommended clearance for your ATV. If .002 and .003 is what it says in your owners manual, that's what I'd use.
Q
Old 03-02-2008, 03:52 PM   #29
bisaho15   bisaho15 is offline
i have 240 miles on my lf200gy. it has alot of ticking when the engine is hot. i bought it off someone who knew nothing about bikes and it wasnt running when i got it. 2 hours of tolling around has this thing in nice shape. but it does tick alot. should i wait till 500 miles to adjust and hope it breaks in. i dont think the kid i got it from broke it in at all and im sure its seen redline alot.
Old 03-02-2008, 04:16 PM   #30
Q   Q is offline
No need to wait. It'll tick when warm even when it's adjusted.
Q
