#16 | |
http://www.mychinamoto.com/downloads...2EC-Manual.pdf |
#17 |
well if he didnt need it I sure did even tho its not my bike but it has alot of info in it for me owning a roketa gy-200 thanks chrome I'll put it to use
#18 |
DW, your chain is likely finished. It will have stretched in the bushings from being too tight. You can pick up a new RK or DID chain for between $20 and $30 at the local bike shop (non o-ring that is; o-ring style is more $$).
If you really want to know the optimal tension, put the bike on a stand, remove the rear shock and block up the rear wheel (I use a small jack) until the rear axle, swingarm bolt and the center of the front sprocket are in a straight line. This will be the tightest point in the swingarm travel; this is where the chain can be snug, without being tight. Put the shock back on and put the bike on the ground without a rider, and you'll see how slack the chain should be while unloaded. Cheers!
#19 |
I was reading through my YZ service manual tonight and it has this for instructions on chain tension. Just another option.
DRIVE CHAIN SLACK ADJUSTMENT 1. Elevate the rear wheel by placing the suitable stand under the engine. 2. Check: ◠Drive chain slack above seal guard installation bolt. Drive chain slack: 40 ~ 50 mm (1.6 ~ 2.0 in) NOTE: Before checking and/or adjusting, rotate the rear wheel through several revolutions and check the slack several times to find the tightest point. Check and/or adjust the drive chain slack with the rear wheel in this “tight chain†position. |
#20 | ||
Nice of You to pitch in ![]()
#21 | |
![]() Spud ![]()
#22 |
I readjusted the chain with my son on the bike. This time I beared down as hard as i could with the longest breaker bar i have. I dont think i am very strong so i think 50-65lbs is a lot for me. It seems to be holding up after only a few rides. It may be time for a chain soon. I am almost out of positions on the adjuster. Right now its on third one from the last.
Seems like the chain must wear out fast, i mean the bike has only 1000 km on it and the chain has never been adjusted too tight. But it has been ridden on sandy back roads/trails on occasion. |
#23 | |
![]() The stock drive chains on many motorcycles wear quickly. ![]() ![]() ![]() http://chinariders.net/modules.php?n...ewtopic&t=7356 Spud ![]()
#24 |
It might appear that the chain isn't too tight, but you don't see what happens to it under full suspension compression. The chain will be at its tightest point when the center of the rear sprocket, the swingarm bolt and the center of the front sprocket are in a straight line. When the suspension is compressed to that point, the wheel is spinning, allowing every link bushing to stretch a bit. What is referred to as tolerance stack-up adds the slop in each link that appears as a loose chain. It is typical to then tighten the chain again and repeat the cycle, stretching the chain further. The reality is that the chain is likely too tight at each stage.
If you start with a new chain, ensure that it isn't too tight at the point of alignment described above. The chain will live a lot longer.
#25 |
Chain replacement.
Bike has 2500 miles on it now. So I ordered some spare chains. Now want to change the original chain out.
I have a couple simple questions regarding replacing the chain. 1. Is it possible to to get the chain on without taking off the left crankcase cover. ( i am thinking not) 2. Is it necessary to drain the oil in the bike to remove the left crankcase cover. What i mean can the bike be laid over on its right side without draining the oil out to take the left side cover off. Just curious, but i think i might do the oil any way since its due in about 250 miles. 3. Once the left crankcase cover is off, do i need to be concerned with anything popping off, (springs flying out, ect) Thanks in advance. Dave |
#26 | |
Re: Chain replacement.
![]() First, place the transmission in neutral. Remove the bike’s chain guard. Then rotate the wheel until the master link is positioned on top of the rear sprocket. Remove the master link, but let the old chain remain on top of the rear sprocket. Attach the new chain to the old chain with the master link and face plate, but don’t attach the chain retaining clip. Then pull the bottom of the old chain to the rear, and the old chain will thread the new chain around the countershaft sprocket. ![]() ![]() I frequently use a different method, however. Once again, place the transmission in neutral. Remove the old chain entirely. Then push the new chain up against the countershaft sprocket from the top and rear of the left crankcase cover. Hold the chain up against the teeth of the countershaft sprocket with your right hand, and rotate the countershaft sprocket from below, with your left hand. If you fiddle with it a little, the new chain will thread itself onto the countershaft sprocket. Then continue to rotate the countershaft sprocket until the new chain exits the bottom of the crankcase cover. ![]() Since you can easily replace the chain without removing the left crankcase cover, I would not do so until I was ready to make the Zong's left crankcase cover modification. ![]() Spud ![]()
#27 | ||
You also asked several other excellent questions regarding the Zongshen 200GY-2, Dave.
![]() ![]() Quote:
![]() ![]() Quote:
![]() Also, you must support the left crankcase cover on a small box, or suspend it somehow from the left footpeg. The stator and pickup coil are attached to the left crankcase cover, and their wires are connected to the Zong’s electrical system. If you let the crankcase cover hang by the wires, it might fall down, or it might loosen the electrical connections. Even if you support the left crankcase cover, make sure the electrical connections are tight when you finish, or you engine might not start! ![]() Also carefully watch the gear that transfers power from the starter motor to the flywheel. A metal shaft that inserts into the left crankcase cover supports this gear. Sometimes this shaft comes off with the cover, and the gear might fall to the ground. Before you ever decide to remove the left crankcase cover, I strongly encourage you to read the thread concerning my left crankcase cover modification. http://chinariders.net/modules.php?n...ewtopic&t=7559 You must remove the entire left crankcase cover to properly inspect, or replace the Zong's countershaft sprocket. Therefore, I always encourage everyone to perform the left crankcase cover modification the first time the cover is removed. ![]() ![]() Spud ![]()
#28 |
Thanks Spud, as always, you are the best.
I think I am going to try to get the chain on without pulling the left crankcase cover. I had similarly tried to attach the new chain to the old chain but i had attemted from the bottom and rolled the bike backwards. When i did that the chain became too loose and slipped off the front sproket. ![]() So right now the old chain is off the bike, but will try your method of threading it on the countershaft from the top and down. Hope my hands fit in there. thanks again. Dave |
#29 | |
![]() If you are patient, you can definitely get the new chain mounted using this method, Dave. I frequently remove my chain to soak it in kerosene for a thorough cleaning. Since I have performed my left crankcase cover mod, I can now easily remove the rear of the left crankcase cover to gain easy access to the countershaft sprocket. However, mounting the drive chain using this method is so convenient, I usually leave the crankcase cover on, and thread the drive chain around the countershaft sprocket as described in the previous post. ![]() Here are a few extra hints. Put the transmission in neutral so you can spin the countershaft sprocket with the fingers of your left hand. Remove the chain guard. To stabilize the free end, lay the new chain on top of the rear sprocket, with just enough chain going forward to thread around the countershaft sprocket. Place the forward end of the drive chain on the swingarm, and thread the chain through the white, plastic chain slider. Now the chain should be solidly supported by the swingarm and chain slider, with just enough extra chain available to thread around the countershaft sprocket. At this point, get your left hand under the left crankcase cover, and feel for the countershaft sprocket with your fingertips. You don't need to grab the countershaft sprocket; you just need to be able to rotate it in a clockwise manner. ![]() ![]() ![]() If your hand is too big, you can use a small stick, or a ruler, to spin the countershaft sprocket counterclockwise. ![]() Once your left hand is in position, and you are rotating the countershaft, slowly slide the drive chain forward in the chain slider, toward the countershaft sprocket. Don’t shove too much of the chain in at once. You want the rotating teeth of the countershaft sprocket to grab the end link of the chain, but you don’t want the chain to bunch up on top the countershaft sprocket, making the job more difficult. ![]() ![]() This process is much more difficult to describe than to demonstrate. If I lived closer to you, I would gladly come over and show you how it is done. Once you learn this technique, the process only takes a minute to perform. ![]() Your right hand does not need to touch the countershaft sprocket. You only use your right hand to slowly shove the drive chain forward, through the chain slider. If your left hand is too big to spin the countershaft sprocket, ask a child, or a woman to help you. Two people should certainly be able to accomplish this task in short order. ![]() ![]() However, sooner or later, you are going to need to replace your countershaft sprocket. When that time arrives, you will definitely need to remove the entire left crankcase cover. Search the TW200 forum for posts describing this process. For example, here is a link to a representative thread describing this procedure. http://tw200forum.com/forums/37343/ShowPost.aspx You might also want to read my thread concerning this subject. http://chinariders.net/modules.php?n...asc&highlight= If you plan ahead for the countershaft sprocket replacement, you can have all the parts ready when you need them. ![]() ![]() Spud ![]()
#30 |
Replacement chain is on my sons zong! I didnt even need to take off the chain guard. Thanks Spud!
Took the bike on a 30km ride tonight, still running great after the first 2000 km of my son riding it. Just curious, what range do most get on the zong? We are seeing about 100km per tank. Is that what others are seeing? The weather is getting colder here in NJ, and i noticed tonight, i could get the bike up to 120 kph, or about 74mph. Probably the colder denser air or the bike is really just broken in! Still thats not bad for a little 200cc chinese bike. |
