02-07-2023, 01:35 PM | #16 |
hi clash! thanks for the reply. will give that a go. not had chance today, woke up with a trapped nerve in my shoulder... agony! will report back asap.
what is the reason for disconnecting the ground for the shut off from switch and or computer? i will try that but i like to know why i am doing something. no sign of corrosion - i keep it indoors and am a 'fair weather biker', plus being in spain helps! it only has 3 fuses so i will check them out. cheers! |
02-08-2023, 01:30 AM | #17 |
I read on here or saw on youtube that one of the grounding shut off wires could stop it from running. Might not help.
02-08-2023, 02:58 AM | #18 |
hi clash. thanks for the update - so it would start and run briefly and then die if the shut off wires were grounded? i will look into it. thanks again.
02-08-2023, 10:25 AM | #19 |
I can't remember. I think it wouldn't run at all.
02-08-2023, 10:47 AM | #20 |
Order a coil. They are cheap. I assume you installed a new plug. Is it getting a good strong spark when cranking?
02-08-2023, 11:02 AM | #21 |
hi jerry - what is 'under a coil'? not sure what you mean.
re: spark plug, yes, new, but as i said at the start - i tested the spark plug when i turn the engine over it sparks for 2 seconds and then nothing until i switch off the ignition and back on again. still the same today. it's as if the ecu is killing the spark within two seconds - same each time. battery fully charged. re: error codes - i get error codes if i unplug things like temp sensor / tps / iac / fuel pump. no error if coil unplugged but i don't think it monitors coil connection (?) ohms check on stator and pulse look within tolerance. would a coil just die after being great (new bike 3 and a half years ago) - it was standing for about nine months and no issues on last day i rode it. cheers! |
02-08-2023, 11:09 AM | #22 |
Yes a coil can go bad. Your coil will look similar to this one. https://www.amazon.com/Replacement-P...s%2C174&sr=8-6
02-10-2023, 08:03 AM | #24 |
coil arrived but they sent a single wire coil! wil be sending back!
02-10-2023, 08:12 AM | #25 |
It should still work. The single wire is the power source. All you need to do is ground the coil to the frame.
02-10-2023, 10:20 AM | #27 |
sorry to day it didn't work. :(
02-10-2023, 10:51 AM | #28 | |
02-13-2023, 04:45 PM | #29 |
ordered a coil from a different amazon seller and waited in all day for it, the tracking said 'out for delivery by 10pm' and just after 10pm they messaged to say 'nobody home' - classic courier b.s.! so now i have to wait again! aaarggh!
p.s. could not use the single pole coil as the efi system on my bike uses 2 wires, one is 12v and the other is used to ground the coil via the ecu, which is how it generates a spark. connecting the single pole coil with the body permanently earthed causes a blown fuse! |
02-14-2023, 10:46 AM | #30 |
new coil arrived. description said '2 pins' - photo showed coil with 2 spade connectors. coil they sent was a single pin coil!
arrrrrrrrrrrrrrrrrrrrrrrrgggggggggggggggggggggghhh hhhhhhhhhhhhhhhh! |
