Old 04-29-2013, 10:38 PM   #16
humanbeing's Avatar
Originally Posted by zingshoen
... humanbeing, it s a 230 zongshen, so pretty much a crf copy...
Chinese 230 (65.5x62.2) is based on the MD33 (domestic version in Japan) | CRF230 (ME09). There's little difference btw them. For example: Piston compression distance is ~0.2mm difference.
ZS http://item.taobao.com/item.htm?id=12980694190 is using the std CB stator (10+ Amp output)
Many "hardcore" chinese" fitted kickstart in the 5 speed machine. :P
Old 04-30-2013, 07:48 AM   #17
zingshoen   zingshoen is offline
zingshoen's Avatar
thanks humanbeing, i also have kickstart, but without decompression it can become hard work :-) i used this bike for 10 years with kickstart only and i thought electric starters are for girls. but with the 230 without decompression i don t like it :oops:
do you know the spark plug for the zong 230?
for the crf 230 the manual says a sparkplug with a longer tip (not a longer plug, just a longer tip), NGK DPR8EA-9, not just the DR8EA.
can the Zong 230 only use the DR8EA, or is the DPR plug better?
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 04-30-2013, 09:59 AM   #18
humanbeing's Avatar
DR8EA works BUT they're NOT the recommend type in Honda.
"...-9" is SAME price as "DR..." , worth to try them in "plug chop" test.
