04-07-2017, 03:11 AM | #196 |
So I asume this is a full flow system ?...
wondering if 10mm banjo fittings could be a bit on the restrictive side for full flow... ..
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 04-07-2017 at 03:59 AM. |
04-07-2017, 11:54 AM | #197 | |
Not sure but i know they have sold thousands of these....... |
04-07-2017, 01:45 PM | #198 |
The most important features to me are two. One, the oil take-off is right in the higher pressure and flow of the lubrication system, and two, the lines and radiator add at least a half a quart of oil to the system, if you add a check valve in the line to the oil cooler. If you don't put a check valve in the pressure line, it will drain back into the crankcase at shutoff. Which means you will have to figure out where full really is. In other words, without a check valve, and with the oil to the normal line in the window, once the engine starts, there will only be a half a quart in the crank case. Adding a half a quart of oil would be a 50% addition of oil to the system. Cooler oil is a good deal in these engines.
04-07-2017, 01:51 PM | #199 | |
04-07-2017, 02:19 PM | #200 |
ohhh im liking this new design.
2016 Green Bashan Brozz. |
04-07-2017, 03:50 PM | #201 | |
Last edited by Ariel Red Hunter; 04-07-2017 at 03:52 PM. Reason: re-arrange words |
04-07-2017, 04:17 PM | #202 |
inlet into the top of the cooler , out let at the bottom..
and the inlet line will be the only part that can drain , not the cooler as well. .
04-07-2017, 05:16 PM | #203 | |
http://www.ebay.com/itm/3-8-10mm-Non...-/252619748975
04-07-2017, 06:38 PM | #204 | |
04-07-2017, 06:42 PM | #205 |
Funny, I heard that same thing from the shop mechanic when I complained of a KH Harley-Davidson wet sumping.
04-15-2017, 11:20 AM | #206 |
How about an update?
Ok, it's been a week. Any word on a release date yet?
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
04-15-2017, 10:19 PM | #207 |
Still waiting on DHL........... |
04-19-2017, 08:06 AM | #210 |
I like the stack plate cooler. Are these ready to ship or did you just get the prototype? Shouldn't there be a rubber seal on the end of that adapter? I'm so......
