Old 10-06-2018, 06:11 PM   #181
Fumblecopter   Fumblecopter is offline
Exhaust leak at head
My bolts holding the exhaust on the head rattled loose and after tightening them it still leaks...anyone know what gasket is a good replacement?
Old 10-07-2018, 12:06 PM   #182
Douglass   Douglass is offline
Douglass's Avatar
Here is what I used, so far no issues. I have about 11 hours on it.
https://www.ebay.com/itm/SCOOTER-150...AAAOSwVFlT4wLZ
Old 10-11-2018, 10:45 AM   #183
Paul2   Paul2 is offline
Hmmm, I have the same as you and times wonder the point of water as well in the cooling fan.
Its also really low and not protected.
Old 10-11-2018, 12:21 PM   #184
studs
there should be studs in there.... you have to remove t he nuts.. then tighten the studs into the head so they are good and tight,,, then put the nuts on there,,, the heat will not let locktight would due to the high heat temp.. so made sure they are bottom out and tight,,, then you can put lock washers on or self locking nuts ... or double the nuts if you can get them on... you can always put longer studs so you can double nut it..
ABIBABA ATV ETC
Old 10-12-2018, 06:58 PM   #185
Thanks!
Old 10-13-2018, 09:09 PM   #186
Weld broke on motor mount!
Ok, just hit 32 miles and I broke a weld on one of the motor mounts. Any suggestions on a good fix? The metal is pretty thin so not sure welding will work well.
Old 10-14-2018, 11:17 AM   #187
Forgot to circle the broken weld area.
Old 10-14-2018, 12:33 PM   #188
Douglass's Avatar
here is what I did to repair mine. When Mine broke the actual pipe broke around the weld. About 11 hrs so far so good with the repair. We used a thicker piece of metal connecting to the engine.
Old 10-14-2018, 10:41 PM   #189
Very cool! Must be a problem all the Bull 200s will have. I'm sort of considering adding a rubber bushing somehow in what I do for a fix...but what you did certainly looks great too. Thanks for showing what you did.
Old 05-27-2019, 09:08 PM   #190
Anyone found a head for the Bull 200's 169cc engine other than the one from partskit.com that has the rocker assembly? My exhaust stud broke off in the head and I can't get it out...will see if I can tap it later but just want to get it back up and running.
Old 05-28-2019, 09:37 PM   #191
head
if you are not good at removing broken bolts... and drilling them... take it to a machine shop... ask for a quote .FIRST... better than replacing the head.... you can also weld a nut on the end iof the broken bolt.... usually have to use a stick welder... mig is not hot enough to weld it good and hard... then remove it...
ABIBABA ATV ETC
Old 05-28-2019, 09:39 PM   #192
exhaust pipe
I always use the copper looking ORING SEAL.... that way it seals the pipe to the block.... can get it anywhere they sell atvs, dirt bike parts.... just might be more than EBAY OR STUFF LIKE THAT..
ABIBABA ATV ETC
Old 06-09-2019, 01:25 PM   #193
I hot the broken stud out with a reverse drill bit! Looks like the stock studs are 8 mm x 35mm...any recommendations for better studs and where to get them? I do plan to chase the threads before I reassemble.
Old 06-09-2019, 02:06 PM   #194
Douglass's Avatar
Just get some from ebay. Ditch the little circle gasket, and get a GY6 gasket, apply a little orange rtc to the nut threads, and torque to about 80-90 inch lbs
Old 06-09-2019, 02:56 PM   #195
I picked up the gasket you said to use so I'm all set there. Thanks for all the help...I was getting pretty frustrated but finally got it out after a lot of patience.
