05-05-2020, 02:51 PM | #151 |
Your oil cooler kit included a finned canister labeled on ebay as a auxilary filter canister. Did you happen to measure the insides to find out what would fit,without causing overpressure of course. My thoughts are (if nothing better around) if it is larger than a stock screen to use a screen with smaller openings with the total area just over stock. A flow test could be done by pouring a measured amount of hot oil thru each and timing each. Thoughts? Thanks! Jack
05-05-2020, 02:58 PM | #152 | |
05-06-2020, 03:51 AM | #153 | |
It is not a very fine mesh, so it will still not filter fine particles, but it will catch things a bit smaller than the screen will and has a much larger area. The catch is you have to be willing to deal with finding it and then ordering it through Taobao. Personally, I would save your time and money and stick with the screen. The screen and oil spinner method has been used by Honda for decades on small engines, and is still being used on their 125cc bikes like the Grom. The spinner takes care of fine metallic particles, the screen protects the oil pump from larger metal particles, and the oil suspends the organic stuff. Just do regular oil changes and that motor will last quite a long time.
05-06-2020, 03:51 AM | #154 |
05-06-2020, 04:00 AM | #155 | |
As Jerry said, leave the space open so air can get to the head and cylinder more freely. I mounted mine as high as I could on my Hawk to keep that space open. Pic if interested. https://ibb.co/Nrmp12C
05-06-2020, 08:06 AM | #156 |
The coolers on my Hawk are smaller than what we installed on our X22R. Those two cooler are about equal in size to one of our coolers.
08-24-2020, 11:33 PM | #157 |
A BAD link...
Hi Jerry,
Your link for the: SpeedoDRD-U1 is bad... Just to let you know... Joe... |
08-25-2020, 07:23 AM | #158 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 08-25-2020 at 09:56 AM. |
