03-28-2017, 10:26 AM | #151 | |
Today, now SSR does the sales and support end of it, as Qlink closed their doors a few years ago. That said, all manuals, exploded diagrams and parts are still available on their old website. Q has been a prenominal bike for me and has never given me any problems in all the years. Just maintenance and of course, cleaning. ;-)
03-28-2017, 01:55 PM | #152 |
03-29-2017, 06:42 AM | #153 | |
03-29-2017, 10:41 AM | #154 | |
We rarely ride at night but I'd like to have something in there better than the stocker....
03-29-2017, 09:52 PM | #155 |
I fixed the horn on my Hawk yesterday (loose connectors). Since then two people have pulled out in front of me.
Thinking about unhooking it again.
2016 RPS Hawk 250, exhaust, Uni Filter, Mikuni VM-26 clone w/ 120 main & 30 pilot, MSR shifter, 17/45 sprockets, JT chain, digital cluster... |
04-05-2017, 09:45 AM | #156 |
Front and rear tie downs worked great. The rear was always a pain to tie down trying to get the hooks around the frame. I tested them out over the weekend. So much quicker and easier to strap everything down. Now I need to do the same on my daughter UTV.
05-04-2017, 09:56 AM | #157 |
I installed the 17 tooth sprocket yesterday when I got home. It only takes about 15 minutes to change out and no issues with anything hitting or rubbing. Only got to take a short ride down the street (about a block) before the rain started up again. Didn't seem to make a big difference on low end take off so it should be good to go. Weather will be nice and sunny for the weekend so I'll get to see how it runs on top end for street riding. It doesn't seem to be to high geared for off road so I'll bring the 15 just in case the next time I go. It's an easy swap changing the front sprocket so I can always swap out to the 15 tooth when I'm out there.
05-04-2017, 05:48 PM | #158 |
I got tired of the pathetic front brake performance on my TT so I switched to a different master cylinder with a bigger piston to help with its woes. Now if I could just find a good set of brake pads for it I'll be set.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
05-08-2017, 10:30 AM | #159 |
So I got to test out the 17/40 sprocket combo over the weekend. The gearing seems perfect for highway. Its nice cruising 60-65 without the motor screaming. I did take it up to 71 mph for a short run. It should still be good for off road riding as long as it's flat land like most of south Louisiana is lol. But think i'll have to put the 15 back on when I go trail riding in north LA. where there are a lot of steep hills on the trails. I couldn't decide to go with the 16 or 17 but glad I went with the 17.
05-08-2017, 11:06 AM | #161 |
Nice picture of the bike.
05-08-2017, 12:33 PM | #162 |
Did the handlebar rust develop from leaking brake fluid?
05-08-2017, 02:02 PM | #163 |
I've gone through this thread numerous times and see people responding to a comment about rear tiedowns, but, can't find the comment they are referring to.
05-08-2017, 02:07 PM | #164 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-08-2017 at 04:57 PM. |
05-08-2017, 02:34 PM | #165 | |
