03-15-2017, 09:53 AM | #151 | |
Jerry, I thought of leaving the cooler but you know someone with a red or green bike wouldn't like the blue anodized spacers lol. Anyways they are available in black. The rock guard was an afterthought but i think it will make a nice addition. |
03-15-2017, 09:56 AM | #152 |
Yeah that part would have to be black or left clear anodized.
03-15-2017, 10:00 AM | #153 | |
My valve cover is over 3" tall. That one looks like half that tall.
03-15-2017, 10:05 AM | #154 |
I'll have to go measure mine today.....
03-15-2017, 10:09 AM | #155 |
So what are the 2 holes on the very top of the valve cover for? Mounting point? Do they go through the cover? Looks like something for a heat sensor maybe?
03-15-2017, 10:11 AM | #157 |
That might come in very handy.
03-15-2017, 10:14 AM | #158 |
If Blaze owners dont have to drop our engines to adjust our valves buying this kit would make our bikes much better.
03-15-2017, 10:39 AM | #159 |
Is there any reason the cooler couldn't be mounted higher? I know the oil would drain back to the engine but a check valve could be installed to prevent that from happening.
03-15-2017, 11:37 AM | #160 | |
I could not get it any higher due to the crossbar holding the plastics........ |
03-15-2017, 11:56 AM | #161 |
If I had one in hand i'm sure I could figure it out. Just let me know when they will be ready and how much. I would rather it mount up higher.
03-15-2017, 12:35 PM | #162 | |
This pic might help. When i fit it originally i cut a block of wood to see where it would fit best. I just couldn't make it work any different. A few have spaced down the fender for clearance and mounted it horizontal. I really didn't like that idea as warm air from the cooler was blowing on the engine negating any benefit IMHO. Your results will vary. Cooler is 210mm long, 38mm thick and 85mm wide. |
03-15-2017, 01:03 PM | #163 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-15-2017 at 04:36 PM. |
03-15-2017, 09:01 PM | #165 |
see the rounded parts on top that look like tubes? same on the inside with two or three holes in one of them.
