07-05-2021, 08:35 PM | #1 |
Sprocket question..
So my rear sprocket is wanting to loosen up on me - only four bolts on my X-Pro DLX / Orion RXB250. The book states 19ftlbs when alllll the rest of the manuals for the Hawks and others are much, much higher... I'm just wondering if I should up the torque??
I do NOT have a snap ring on the sprocket.. the sprocket is just attached with 4 bolts. I have applied some Loctite 242 blue the last time I noticed that one of the bolts was almost, like within a few millimeters of hitting the swing arm.. Had I not turned around when I did; may not be writing this now! I'm seeing around 35-40ftlbs for bolt torque, not 19.. Also wondering if anyone with the RXB's could share their torque specs for the rear sprocket just for comparison. I did look through the resources but I don't think this one is the same for the Hawk fix. There is no play with the sprocket when the bolts are tight either; it's all like it should be when tight. But this happens maybe around 250mi? I have thought about changing out rims because these are just.. meh, but didn't know size or anything to get for my bike... Anything would help! Most definitely some torque info for others rear sprocket spec. Thanks!
07-05-2021, 10:01 PM | #2 |
Okay - thoughts..
I'm thinking about taking one of the bolts from the rear sprocket to the local Ace, size it up but get a longer bolt, but not too long - grab some lock nuts, and secure it like that.. the hub does have the threads and goes through the whole hub piece.. There wouldn't be any interference in the bolt flowing through the hub whatsoever.. and from inside won't be touching anything or in danger of spinning and catching on anything.... As long as I'm alright with distance, that SHOULD provide a fix.. and not come loose. Hopefully. But - I would like to run this idea by some of the vets of the Chinese bike world to see if this is even acceptable for a fix. The front sprocket bolts are good - same torque that I had them on when installed. The rear just, doesn't need to be coming loose like that.. This is the only thing I can come up with without over-torquing the crap out of the rear bolts and stripping the hub...
07-06-2021, 05:35 AM | #3 |
I just looked up torque specs for my Honda XR250 and it is 27-33 ft lbs. My rear sprocket attaches with 5 bolts with nuts, I will check the bolt size when I get home.
2022 Venom KPR 200 Red- the fastest color 16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS 2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat 2022 Venom Ghost chopper 250 1997 Honda GL1500 Goldwing 1978 Kawasaki KL250 https://youtube.com/@herbiesgarage681 Last edited by herbie; 07-06-2021 at 02:19 PM. |
07-06-2021, 02:57 PM | #4 |
Hawk/Brozz etc. use sprocket studs for the cush drive and the sproket is retained by a snap ring. That is why the torque spec is 30-35ft-lbs. I would not use those figures on your bike unless somebody else can confirm they have used them without issue.
The longer bolts is a good idea as the more threads are engaged, the better. Loctite is also a good idea, just make sure to clean the thread surfaces before use. Any oil, grease, or even old loctite will reduce its effectiveness. Brake parts cleaner/carb cleaner isopropyl alcohol, or some other form of degreaser will do fine. Heck, dawn dish soap and a brush works too lol. The lock washer is also not a bad idea, and I have used those with loctite just to be double sure on some fasteners. Maybe it's overkill, but overkill beats death every single time.
07-06-2021, 06:36 PM | #5 |
I think I misunderstood, after rereading, I would not exceed the OEM rated 19 ft lbs either. If you're screwing the bolt into an aluminum hub I would think at about the 25 ft lb range you would probably have stripped threads or close to it. The longer bolt and nut makes good since to me if there are no clearance issues. I'm glad Dan jumped in there before something bad happened
07-07-2021, 07:21 AM | #6 |
AWESOME! Thanks guys - was kind of scratching my head on why this rear sprocket keeps loosening up lol
I'm going to keep it at 19 - well, 20ftlbs; my torque wrench doesn't go down to 19ftlbs! I had went to 20ftlbs last time I tightened it up, had to go to 20.... but no strips, nothing that would scream out 'UNSAFE' to me. So yeah, I'm gonna' just grab some lock nuts and some longer bolts to get this thing tight. MegaDan - that makes perfect sense about the snap ring and higher bolt torque; went right over that fact. Will be visiting Ace soon to get the right stuff.
07-08-2021, 02:02 PM | #7 |
Thanks Megadan
07-08-2021, 07:33 PM | #8 |
Got my new bolts / lock nuts; got 'em on without any problems!
Going to take it out for a spin sometime to make sure it's locked in nice 'n tight; recheck the torque around 75 - 100mi. I'll post back my results after I get some time to ride. BTW any suggestions for filter oil? I have some 90Wt. oil, was reading any heavy oil can be used to reapply the oil coating for the filter. Thanks again, MegaDan and Herbie!
05-17-2024, 04:57 PM | #9 | |
05-17-2024, 07:25 PM | #10 | |
Blue (medium) has always been sufficient for my Hawk, and even after thousands of miles they are still holding tight. Serrated flanged nuts are ideal, and they also help prevent loosening. 2 lighter methods of retention > one overkill method.
05-17-2024, 10:53 PM | #11 |
I've always put my bike in 1st gear, and my wrench on the nut or bolt towards the center of the wheel. Never in the direction facing outward.
It has always been enough for me to loosen bolts that way. On Chinese bikes, which need frequent maintenance, definitely blue locktite is a good option, though sometimes it's not even necessary. I would take a spare nut from a variety pack I own, and just add the second nut to keep the main one in place. |
05-18-2024, 08:31 AM | #12 | |
05-18-2024, 01:30 PM | #14 |
Sorry for the confusion, your correct, my Storm 150 DLX has the same sprocket set as yours. My Hawk 250 DLX is a different setup and that is what I was talking about in my above thoughts. Thanks for your thoughts as I have both! I should have looked over the post from the beginning
05-18-2024, 01:58 PM | #15 |
Just for fun my Xpro 150 has locking tab between two bolts, two of them obviously on the rear sprocket.That’s is a great way of keeping things from loosening. I’m liking that Xpro bike more and more as I look at it.
