#17 |
#18 |
It looks fantastic near you; you should change its place in your garage. I dreamed about a Kioti CS2520, but I need to find a good reseller who can sell these products in excellent and verified condition since I am not ready to pay the full price. I hope anyone here knows more than me; if so, please suggest something!
#19 |
I totally get wanting a Kioti CS2520 without breaking the bank. I've had luck finding great deals on gently used equipment through local farm equipment dealers and sometimes online marketplaces. Sometimes, the best deals are at local farms that are updating their equipment. I live near Denver and found an amazing deal on a barely used tractor with a short car drive. They also have a website where they update what they have in stock, so you might find farm gear here since they have multiple locations.
#20 | |
The biggest difference is that the Kioto and other lighter tracters with true 4WD can have a light footprint. This can be really important when the ground is WET! It also minimizes gouging and digs caused by uber machinery ![]() If it is a golf course (ok, maybe a back yard, or lawn ![]() I am in the process of planning a move. I do not want a big lawn to maintain, and I'd rather have tillable garden space. When the time comes, I will be leaning towards ancient machinery.
#21 | |
My little LS has the rear tires filled with water and that definitely helps stick it to the ground on our steep hill. It's amazing what that little thing has accomplished. Zero problems.
#22 |
I guess 4WD is just better for tractors. I had a small ford tractor (8N) inherited on the property (needed engine work-a cylinder was bad). I never got stuck at all. But I didn't venture into mucky fields. It was a heavy tractor, but it was good with the rear lawn mower. I did not have a shovel on it. I did need to use the brakes selectively in soft dirt, but never bogged down.
#23 | |
