Old 09-27-2023, 04:46 PM   #1
Notbostrom   Notbostrom is offline
200 168 efi scooter fuel pump
My particular scooter is a vitacci force 200 efi but I'm sure most of the newer efi scooter use the same fuel pump assembly. Anyone found a non dealer source for these?
My pump works fine but fuel gauge not working so might have to replace the whole assembly.
Also anyone have a wiring diagram?
Old 09-27-2023, 07:21 PM   #2
Update
Looks like a Honda pcx150 pump is identical as far as I can tell. Also for me no parts were necessary the rod for the fuel gauge sending unit was just very stiff.
Old 09-27-2023, 07:29 PM   #3
Mudflap   Mudflap is offline
I've taken the unit out of my Clash to have a look. It's a very simple unit with only 4 wires if I recall correctly. 2 wires to the pump motor and 2 to the fuel level sending unit . Very easy to test on the bench with an ohm meter.
Old 02-14-2024, 03:38 PM   #4
Purpose   Purpose is offline
Originally Posted by Notbostrom View Post
Update
Did this work? Believe my Tank 200 is in need of a fuel pump.
Old 06-07-2024, 02:21 PM   #5
MadClash200   MadClash200 is offline
I have a Clash 200 with 115 miles. It ran great till yesterday. When I turned the key didn't hear the fuel pump run and of course no start. Any thing I should try before replacing the pump?
Old 06-07-2024, 02:53 PM   #6
Check the pump before replacing it. Verify it has power at the connector at the pump.
