Old 07-24-2023, 12:13 AM   #16
bigdano711's Avatar
I'm gonna have to read that at least ten times for maybe half of it to sink in. Dude, I've learned more about engines in that one post than the sum total of all my attempts to learn engines. Engines, to me, are like computers to some people. MAGIC. Crazy engineering and science, too.
I looked at a computer and just "got it". I look at an engine and I can see a couple major components, but when you start talking about rockers and lifters and cam lobes and valve lash, holy crap does my head start spinning. Like, this is the first time ever I put my hands on a valve and did an "adjustment".
How do I donate to this site?
Old 07-24-2023, 09:02 AM   #17
TominMO   TominMO is offline
Here's a good overview vid on motors:
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 07-24-2023, 09:07 AM   #18
All those things you mentioned is just parts of an analog computer in the engine controlling the timing and volumes of suck, press, bang, blow. That’s it, all there is to them. If you reframe your mind to thinking of it as a computer made of analog parts it might help you learn easier?
Old 07-24-2023, 05:38 PM   #19
Jorogumo4   Jorogumo4 is offline
Let the engine cool off again for a few hours, take the valve cover off and the spark plug out. Use the kick start lever to slowly turn the engine over until you see the intake valve (closest to the carb) open and then start to close. Now you know for sure you are on the compression stroke. Now line up the T mark for Top dead center and set your valve lash.
When turning to the t mark for top dead center. Should I be turning it cw or ccw? I turned the motor over with the kick start until the intake valve started to close and turned to the t mark after cw
Old 07-24-2023, 05:53 PM   #20
CCW, looking from the left side; i.e. the direction the motor normally turns. Pull the spark plug so there is no compression. Otherwise you might accidentally loosen the crank nut that you are turning the motor with.
Also, you may find it is impossible to get it to stay exactly where you want it, which is at the proper TDC (both valves closed). You get almost there, then the motor spins past TDC by itself. You have to turn the motor with a solid wrench, not with something that has a ratchet.
2022 Lifan KPX
Old 07-24-2023, 06:10 PM   #21
Originally Posted by TominMO View Post
CCW, .
Could it still be ticking because I rotatated it cw? So I need to redo it again?
Old 07-24-2023, 06:54 PM   #22
XLsior   XLsior is online now
XLsior's Avatar
the push rod OHV (over head valve) CG engines tick especially when cold...its normal.
OHC (over head cam) are a little quieter as long as the timing chain is tensioned correctly.
If the ticking and tapping is regular and responds to revs its the nature of the beast...
when things cackle or clunk irregularly or strained is when the concern starts.
Old 07-24-2023, 07:45 PM   #23
It's regular with the revs. I'll post another video later today. I redid it the way you recommended by turning it ccw. She definitely seems to be running better. But I dropped it trying to find neutral with my new boots today and now it's acting like the brake is stuck. Not sure what's going on.
It's in neutral
Old 08-04-2023, 06:42 PM   #24
So after properly adjusting the valves, then messing with the choke a bit and messing with the idle. Here's what I got. Still seems a bit clacky. Does this sound normal?
https://media.discordapp.net/attachm...804_181941.mp4
Old 11-16-2023, 05:15 PM   #25
BriNbigD   BriNbigD is offline
BriNbigD's Avatar
2023 valve ports
New 223cc engine specs
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 EX400G Ninja 400
2023 Hawk DLX
