04-08-2023, 01:49 PM | #121 | |
05-31-2023, 09:01 PM | #122 |
Does anyone know what bike the KPM200 is closest to as far as a replica? I see people saying the Venom Ghost is a Honda CBF for example, the X22 is a ninja, etc. Just wondering what service manual I can get for the KPM200.
06-01-2023, 08:08 AM | #123 | |
07-12-2023, 09:06 PM | #124 |
KPM service manual
Does anyone have the service manual to the KPM 200? Also does anyone know the best place to buy individual parts for the KPM. I’m working on the clutch right now and might need a part replaced.
Thank you. |
07-13-2023, 07:51 AM | #125 | |
Parts: https://kpclubusa.com/
08-02-2023, 02:18 PM | #126 |
Just wanted to say, I ended up finding and adding a really nice aftermarket speedo. It came from Amazon: https://www.amazon.com/DKMOTORK-Moto...p/B07WW3L3Y8/r
Attached to my post are the wiring guidelines. Instead of replacing my existing speedo, I created a custom harness to piggyback off the existing speedo. If I had spent a ton more time on the wiring, I probably could have made it work and removed the stock speedo -- but I didn't want to be destructive. |
08-20-2023, 11:25 PM | #127 |
Great info on the guage cluster install, would love to see it on the bike too!
2021 Lifan KPM 200 2019 Venom BD578Z E-Vader |
08-30-2023, 12:07 PM | #128 | |
https://kpm200resources.com/aftermarket-speedometer/ |
09-22-2023, 06:04 PM | #129 |
does anyone know if the NGK CPR7EAIX-9 Iridium IX Spark Plug is compatible with the KPM200?
09-28-2023, 09:54 PM | #131 |
Anyone run into an odometer issue with the KPM200? I've only rode about 7-8 miles according to my phone gps but the bike's odometer says I rode 15 miles. That's a huge discrepancy. Any tips on fixing the issue?
10-01-2023, 01:32 PM | #132 |
I just got a KMP 200 from a private seller and think they stripped the oil drain plug. Does anyone have the size/thread specs of the drain plug? I want to try an oversize plug before I have to do the full re-tap of the hole. Has anyone tried this?
11-22-2023, 11:00 PM | #134 | |
https://www.amazon.com/gp/product/B07XLZNYQX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
01-19-2024, 06:36 PM | #135 |
I am probably early but has anyone identified the measurements of seals needed to rebuild the front forks? Is oil quantity same as the KPR200 even though these forks are inverted?
"It's all falling apart like a Chinese motorcycle" - Rodney Dangerfield as Larry Burns 1975 Honda CB750K 1975 Honda CL360 2020 Lifan KPM200 |
