Old 09-02-2022, 07:34 PM   #1
tknj99   tknj99 is online now
2022 Templar X 6sp Review
Wanted to get my initial thoughts down for the benefit of those considering this bike:
Ordering: I ordered the bike from PowerSports Max and the process was seamless online.
Delivery Time: Amazing.. I ordered on a Saturday and received the bike 5 days later
Price: $2150 including $350 shipping
Delivery: I've bought 3 Chinabikes online prior to this purchase and every one of them arrived in a beaten up cardboard metal bent-up crate. My last delivery of the Titan DLX came with the bike shipped upside down, oil all over the bike including seat as well as scratches on the fork caps and exhaust. Well i was expecting the worst but got the best. The box was shrink-wrapped without even a tear at all, perfect condition. Inside, everything was padded and zip-tied and again in perfect condition. I was amazed! I think the vendors are demanding better and getting it from the shippers (R&L Carriers in my case)
Assembly: There are some extra steps you will need to take which are not the norm; the triple-tree and fork tubes are not installed and need to be carefully assembled with the steering parts in the correct order. Luckily the parts are attached in the tree in correct order so you just need to remove them and place down in the order of assembly. This is a good time to actually see the inside of the steering assembly and of course slather it with grease all over the bearings and parts. Note: the bearings are slightly greased from factory and the triple-tree and fork tubes have L and R arrows to align during assembly.. easy peasy. Note: i had my wife slide the jack under the bike while i lifted the bars.. this was probably the hardest part of the build.
I connected the triple-tree to the frame and then afterwards connected the handlebars. Having the bars hooked up allowed me to be able to lift the bike off the metal crate later on to be able to slide a jack underneath in order to connect the fork tubes and front wheel.
The electrical connections were pretty easy to figure out as they only connect to the right receptacle. The L-shaped connector goes to the black box under the triple-tree and the 2 loose wires connect to the horn. You will need to disconnect each turn signal to run the wires thru the top-hole on either side bracket. The headlight assembly connected to the lower hole on each side bracket and then you need to remove the bottom rubber pieces attached to the headlight in order to connect it to the frame mounts.
Once you jack the bike up, you can connect the front wheel using the provided axle and spacers and then connect the brake assembly afterwards along with the speedo sensor. Slather grease on the sides of the wheel hub prior to assembly.
Rear electrical is exposed. I used one of the vinyl cover pieces that came in the delivery and sliced length-wise to wrap the electrical connections and then wrapped in electrical tape and tied it up to the frame
Issues found: only one issue found and that was the throttle side mirror glass was broken. Sent a note to PSM for replacement
Initial maintenance performed before start-up: popped the tank off (2 bolts), removed the valve caps, spun the crank to TDC and set the valves to .04mm (tightened on a .05 adjuster blade which lets .04mm blade thru) I read that others have set tighter than this but i figure this is what i've set the Brozz and Titan to and they perform great plus the valves can only tighten up with time.
Start-Up: Added gas and cranked her up a few times and she started but then stalled a few times. The battery was drained very fast so i hooked up a jump-start to get her running. Fired right up with the jump and idled nicely. I set the idle down to a hair under 2k. Let her run a few minutes, then shutdown and repeated one more time.
First Ride: Well she feels nice and hefty, tall yet nimble. Nice power and acceleration. Throaty exhaust. Smooth on the road with the counterbalanced engine. I got her up to around 60mph and backed off. She will definitely benefit well with a smaller rear sprocket. The 6th gear is great!
Maintenance/Tech Plan: I plan to keep her under 7k until the 500 mile mark for break-in and plan to change the oil at around the 100 mile mark to Rotella 15W40. I still need to fiddle with the suspension settings as well.
Add-Ons: Installed bark busters
Planned Upgrades/Add-Ons: 42T rear sprocket. Fiddle with the carb to shim the needle and maybe increase the main one size up
More to come..
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 09-02-2022, 07:39 PM   #2
More pics
2019 Beta 430 RRS
Old 09-04-2022, 08:32 AM   #3
Installed the 42T rear sprocket yesterday and testes out. It feels much better geared now. 6th gear before had some good acceleration before but now is more of an overdrive. I hit 60 on the speedo at 6k rpm so 70 should be attainable. Any lower gearing in my opinion would be too much of a torque hit. Happy as is.
2019 Beta 430 RRS
Old 09-04-2022, 01:49 PM   #4
captkirk   captkirk is offline
where did u find the 42T or what bike does the rear sprocket come off of. need to get alittle more top end
tia
Old 09-04-2022, 04:59 PM   #5
Link to 42T Rear Sprocket: https://www.amazon.com/dp/B0068OC2T4...roduct_details
Link to Bark Busters: https://www.amazon.com/dp/B07DXVKMVJ...roduct_details
2019 Beta 430 RRS
Old 09-04-2022, 05:03 PM   #6
Changed the oil at the 25mile mark with Rotella 15w40.. and whoa thats a lot of metal shavings. Plan to change again around the 150 mile mark or so.
2019 Beta 430 RRS
Old 09-07-2022, 11:35 AM   #7
PSA: when the rear axle is tightened there is a drag on the rear brake that makes the rear wheel hard to spin. The remedy (thanks dslfrk) is to add a large washer on the inside left of the swingarm. see attached pic. this allows you to torque the nut to the proper spec and/or add a cotter pin for extra safety
2019 Beta 430 RRS
Old 09-08-2022, 09:59 PM   #8
chinazuki   chinazuki is offline
yesterday that is what I used: A jack and a board.
And wished I had put more thought into making a stand for the assembly process.
arkansas
Old 09-08-2022, 10:01 PM   #9
Oh, thats what the free metal from the crate is for...
and custom panniers!
arkansas
Old 09-08-2022, 11:08 PM   #10
TominMO   TominMO is offline
I use the same setup, and hang the handlebars from the garage rafters with tie-downs to stabilize the bike.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 09-09-2022, 04:55 PM   #11
I did not have but barely 1 or 2 small flecks in screen at assembly oil change. As expected, at 100 mile oil change had a few tiny glitter specks in used oil, none in screen. Using same oil as you for break in on mine.
Old 09-12-2022, 07:26 AM   #12
Update: went to the Virginia DMV on Friday and with only a small hiccup was able to register the bike. Since Zuma (listed on MCO as make) was not in the VA registration database, the agent needed to scan and send a copy of the MCO to Richmond. This took a couple hours but it got done same day. The next lucky fella in VA will have a much smoother transaction
2019 Beta 430 RRS
Old 09-14-2022, 02:44 PM   #13
Is that the original rear sprocket on the BROZZ?
arkansas
Old 09-14-2022, 03:41 PM   #14
No it's a replacement 42T rear on the Brozz
2019 Beta 430 RRS
Old 09-15-2022, 08:43 AM   #15
dslfrk   dslfrk is offline
Nice write up, tknj99. I am running a 14-40 ratio and that is working really well for me. It runs just under 1000 rpm per 10 mph in 6th. Still works very well off road.
I tried a 130 main jet and that is too rich, runs better with a 125 main. Went on a long ride and hit reserve at about 100 miles and totally ran out 5 miles later. Lucky a local Dairy Farmer had a gas can and gave me a ride. Need to figure out how to carry more. I guess the reserve isn't very much.
Looking forward to finding some more power even though is goes very well. Really like the bike!
