07-08-2022, 08:00 AM | #1 |
Will an Orion rxb 250 engine fit in a hawk dlx frame?
I was wondering what motors you can buy for the hawk dlx that will fit. I like that Orion is counterbalanced and 6 speed and cost less than the dlx motor new.
07-08-2022, 08:30 AM | #2 |
More than likely will fit but will require fabricating new mounting brackets plus if you want EFI you will need the throttle body, fuel injector, ECU and any other wiring harnesses make it all work.
hawk dlx, orion rxb 250 |
