08-13-2021, 12:11 AM | #31 |
Not super surprising; you did cook the crap out of your catalytic converter when the clogged fuel filter leaned out the engine while you were running down the highway. That would have shortened the life of your O2 sensor greatly. Hopefully that is all that you need to get the bike running right again.
08-13-2021, 09:40 AM | #32 |
Yeah. I went ahead and ordered pretty much every sensor on the bike aftermarket. I did pay big bucks for an OEM stepper motor/IAC valve, but everything else I found very cheaply. I'm going to keep a full set of spares on hand, along with the diagnostic stuff.
Charles. |
08-15-2021, 12:15 PM | #33 |
So my dongle thingy came with three different CDRs labeled Ecuflash Techstream, JLR-SPA, and JLR-PRO 138FULL. These of any use?
Charles. |
08-15-2021, 01:59 PM | #34 |
Take a picture of the interface you have if taxtric here is drivers https://www.tactrix.com/index.php?op...blog&Itemid=61
08-15-2021, 06:14 PM | #35 | |
I'm fairly confident you'll be using that HOD ECU Hacker program for most all of it. Though, you could try other applications like Torque (mobile) or Palmer Performance software (PC) - https://www.palmerperformance.com/ Even has a dyno! But, that would just be to monitor / code read and see what aspects need to be tweaked, and give you a pretty accurate HP / TQ reading (dyno). So the CD's - probably useless for the bike. I'd hang onto them though; can scan your cars if they throw any codes. The CD's might also have the driver for your device - if you're using Windows 10, wont be necessary; Windows grabs the drivers automagically. Except Tactrix, might need to manually install the J2534 driver. I don't know if Microsoft has included that chip driver in their database - but, Lukas has you covered on the download.
|2020 X-Pro Titan DLX| <-- FOR SALE!! Last edited by Plump Kibbles; 08-15-2021 at 08:54 PM. Reason: Clarifying drivers |
08-20-2021, 08:13 PM | #36 | |
That cable from Amazon is the wrong one for the RX3. While it's a 6-pin connector, both the internals and extyernal parts of the connector prevent it from being attached to the RX3's connector. Charles. |
08-20-2021, 08:21 PM | #37 |
Can I cut it apart or is there circuitry in the cable?
Charles. |
08-20-2021, 09:31 PM | #38 |
plug for rx3 is furukawa 6 pin fits from benelli do not combine with other cables because it is not known how the cables are released it is a pity to risk a short circuit I gave you a link to the cable I bought
https://www.aliexpress.com/item/4001...3a994c4dIyFBBK BENELLI TNT 135 (ECU DELPHI) BENELLI TNT 25 (ECU DELPHI) BENELLI TNT 300 (ECU DELPHI) BENELLI 302R (ECU DELPHI) BENELLI TNT 600 (ECU DELPHI) BENELLI GT 600 (ECU DELPHI) BENELLI CAFFENERO 150 (ECU DELPHI) BENELLI ZAFFERANO 250 (ECU DELPHI) BENELLI TRK 502 (BOSCH ECU) BENELLI LEONCINO (BOSCH ECU) |
08-20-2021, 09:36 PM | #39 |
08-20-2021, 09:50 PM | #40 |
I did order the aliexpress one, but then didn't want to wait a month and a half for it to arrive, so I got the amazon one listed well above.
Lukas, I see the new one you've listed and I ordered it, but it's also a week out. Oh well. At least I have a Benelli and an Italjet to ride in the interim. Charles. |
08-21-2021, 12:43 AM | #41 | |
http://www.rx3adventure.com/images/r..._schematic.jpg |
08-23-2021, 10:26 PM | #42 |
Okay, I was able to get everything working and I recorded a few minutes of it running. Here is the logfile:
https://drive.google.com/file/d/1szR...ew?usp=sharing What I'm noticing is that the TPS is fluctuating between 0.5% and 1.4%. Later in the file I try opening the throttle (up to 5.5%) just to see if the tps will snap back to under 1%, but it doesn't. My working theory is a bad TPS. TPS reads high, causes ECU to supply fuel even though throttle body is closed. O2 sensor goes super rich because of all this fuel. But that's a guess. Can you guys tell anything different from the data log I shared above? Thanks! Charles. |
08-23-2021, 10:57 PM | #43 |
Here's a graph.
https://drive.google.com/file/d/1yHz...ew?usp=sharing I blipped the throttle once at the 4 minute mark. Otherwise I didn't touch the grip. Plenty of cable slack FWIW. Charles. |
08-29-2021, 07:26 PM | #44 |
I was busy changing the muffler on the rx3 today I couldn't download the file you should get an email asking you to share the file.
08-29-2021, 09:57 PM | #45 |
I just got home, saw your message, and replied to your email. I thought I had it set to be shared with everyone, I'll doublecheck.
Charles. |
