09-23-2019, 09:41 AM | #76 |
Megadan, there's still a few GT250's and GT650's out there too. https://www.cycletrader.com/listing/...250-5009123616
https://www.cycletrader.com/listing/...650-5009123614
09-24-2019, 08:00 AM | #77 |
What kind of fuel mileage have you been getting?
09-24-2019, 08:52 AM | #78 |
i haven't payed much atten to that yet, but i assume about 60. low engine gas light comes on at 140 miles. i am certain the speedo is off like chondas(says 62 more like 55), and not sure if odometer is off bc speedo is...... i will get the iphone out and see actual speed soon. the low in gas light seems to come on too early as well bc i couldnt put all of the 2 gallons i prepaid in the tank at the point of gas light coming on. btw, i did find a clock built into the cluster, i just didn't have it turned on all this time. this bike is growing on me every time i ride it.
09-24-2019, 09:05 AM | #79 |
Not bad. SpeedoDRD make a universal calibrator. But $70 is a little steep. I bet if I look on YouTube somebody done figured out how to make there own.
Link to speedo calibrator. https://www.ebay.com/itm/SpeedoDRD-U...-/301141666436
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 09-25-2019 at 08:16 AM. Reason: Added link |
01-03-2021, 08:52 PM | #80 | |
This picture is not a standard triple tree just flipped over. This seems to be a tree that I find in pictures from all of the GD 250R as standard in South America/Mexico. I can't find the part though! If I could this would be perfect. |
01-04-2021, 12:18 PM | #81 | |
Ok... The handlebar mystery is SOLVED!. So on the front fender of the GD250R it says E-Suit.. this refers to the optional positioning for the driver. We all know about the foot pegs spacers... BUT for the handlebars they have an "alternate" triple tree top clamp that is designed for mounting the clip ons over the forks without changing the front height dimension. Found it for sale here.. https://www.whygostock.com/gd250r-riser-bracket/ Easy mod after all! |
01-05-2021, 06:48 AM | #82 | |
It seems all the images have disappeared from this thread.
Past bikes: '10 Gio X33 '85 Honda VF750F Interceptor '80 Honda XL185S '76 Yamaha DT250C dual sport Baja Wilderness Trail 250 '07 Honda Shadow 750 Areo Trike '01 Harley Davidson Softail Deuce Polaris Magnum 425 4x4 Quote:
