Old 04-23-2018, 07:52 AM   #241
Took a ride on my Hawk Saturday and went meet up with one of our new Chinarider member and showed him the Hawk. I think he's hooked lol. Hey Frank , Hurry up, Need a riding buddy.
Now that it has warmed up my Hawk is running a little rich. I could barely get 67 mph out of her and was starting to cut out at the higher rpm's. So I got up Sunday morning, Adjusted the valves ( They were a little tight) and dropped down to a 115 jet. (Really needs a 117.5 but didn't have one). I took a 94 mile ride and what a difference. I hit 76mph but had to slow down. The wind was blowing pretty hard and got a little scary.
2020 Kawasaki Vulcan S
Old 04-24-2018, 10:40 PM   #242
WWRAFTER   WWRAFTER is offline
As much as I like the Hawk in black, it didn’t have any depth. So, between rides I masked the plastics off and added some trim color.
Old 05-20-2018, 07:24 PM   #243
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
I'm at about 4000 miles and I needed to change the oil. So I changed it. The bike is barely using any.
Also checked the valves. They still havent moved since I set them after break in, which really surprised me.
Old 11-09-2020, 06:04 PM   #244
What Did You Do to your Chinese Bike Today?
I did the following today to my Brozz Recon 250:
- changed oil at 120 miles to Shell Rotella T4
- Fabricated a bracket bracing for the floppy tail-light/plate assembly
- fixed digital dash turn signal connector which had a bent pin from the factory
- drilled another 4 holes in the stock exhaust back plate for a total of 8 1/4" holes.. increased sound over stock by a good 30% and is nice to hear the exhaust now when revved over the click/clack of the engine.. not loud at all but an improvement and best of all free.
Old 11-12-2020, 03:38 PM   #245
- Installed a cell phone mount
- Installed a 12v USB line mounted to the steering neck
- Removed the airbox snorkel
Old 11-14-2020, 09:46 PM   #246
motochutuya   motochutuya is offline
took a dremel to my levers and blew the knob off...fits behind the hand guards
Old 11-15-2020, 02:28 AM   #247
Musictrek   Musictrek is offline
Musictrek's Avatar
Put an end to the leaking gas cap when I fill a little more than maybe i should. Made in Japan doesn't leak. Crazy though that they are so similar. Japan part on the left.
Old 11-15-2020, 08:50 AM   #248
woodsnwater   woodsnwater is offline
Gas cap on your Brozz? Looks different than my recon cap. The 19' caps are not the same as a 20' model?
Old 11-15-2020, 12:41 PM   #249
cycleway4   cycleway4 is offline
same here...a great upgrade
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 11-15-2020, 01:20 PM   #250
Removed the exhaust header and smoothed out the welded bump on the inside... also for shits and giggles i pushed a rod into the cat and it wont budge, thought maybe i could a least poke thru it with alittle force but no beans
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 11-15-2020, 07:48 PM   #251
Ozzie   Ozzie is offline
Changed the headlight (SO bright!), the rear light cluster, built a new leather seat (in which I installed the rear lights! ...photos to come), replaced the side indicators (which also double up as running lights) and then ripped her around town for lunch! She's lookin fiiiiine (https://www.instagram.com/p/CHnwV8lAnea/)
Old 11-16-2020, 08:38 AM   #252
Installed this tail bag on the rear rack, is a perfect fit and holds all of the items i stored previously in a former mc swingarm bag
https://www.amazon.com/gp/product/B08G7ZKPDW/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
2019 Beta 430 RRS
Old 11-16-2020, 08:43 AM   #253
I have one of those on my X22R. Works great for small stuff.
Old 11-16-2020, 09:23 AM   #254
Thanks. Yes i am quite pleased with its shape, and how it matches the contours of the tail rack perfectly, making it look like it belongs there.
I wanted something minimalist and sleek and this one is highly recommended for that purpose and especially at the price point, cant go wrong
2019 Beta 430 RRS
Old 11-18-2020, 01:45 PM   #255
Completed the fork oil change to 15W - increased tension about 20%
Installed Niche 428 X-Ring 128 Link Chain
2019 Beta 430 RRS
