Old 08-01-2020, 10:00 PM   #1
alex_in_az   alex_in_az is offline
mild steel intake manifold?
I can't seem to find a manifold that'll work with my Nibbi PE30 on my TBR7. is there some reason why I can't just fabricate one from mild steel plate and tubing? I'd make it from aluminum, but I can't weld aluminum with my set up
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 08-01-2020, 10:24 PM   #2
TheChairman   TheChairman is offline
Go for it. If it works well, make a few. They'll probably sell.
The only issue I can think of is heat soak. Someone else here can probably chime in on whether they think that would be a problem.
Old 08-02-2020, 05:11 AM   #3
franque   franque is offline
You might want to get a phenolic spacer between the head and manifold, and make sure the inside of the manifold is smooth. Also make sure you use a gasket to keep it sealed up.
Old 08-02-2020, 12:00 PM   #4
the Nibbi has a rubber hose type mount, so that should help mitigate heat soak
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 08-03-2020, 08:42 PM   #5
Goob   Goob is offline
Here is one you can get..or many others on Ebay or Amazon
Here is one you can get..or many others like it on Ebay or Amazon. This one was recommended by JerryHawk250 I think. Some are as little as $5, not sure if there is any quality difference.
https://www.amazon.com/exec/obidos/A...im/refuge08-20
CSC TT250
Orion RXB 150XL
Old 08-03-2020, 10:13 PM   #6
twinmonkeys   twinmonkeys is offline
I am using this one on my 2020 TBR granted I am running a PWK 30 not the Nibbi
NIBBI Orginal High Performance CQR Intake Manifold Air Joint Boot Connector For Motorcycle Motorcross Dirt Bike Kawasaki CQR250 CRF
It is 15.99 and is Prime. I trimmed maybe 1/4" and it fits and clears the frame. I have the Uni foam filter.
Old 08-04-2020, 03:09 PM   #7
I have that intake manifold, where did you trim it to make it fit?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
