07-06-2020, 10:04 PM | #1 |
The Diesel Project
Almost four years ago, I scored this Lambordini/Kohler diesel from work. 6.5 hp, electric start, less than 3 hrs on the clock.
The plan was to build a cheap to run motorcycle around it to commute to work on and only get fuel maybe once a month. Well, that fell flat for two reasons. One, I don’t commute anymore. Two, I could not for the life of me find a roller with a title. Well, half of that has been corrected and the project is back on. Picking up this basket case of a Suzuki GS550 tomorrow morning. https://chicago.craigslist.org/sox/m...147266998.html Don’t care about the half an engine, but it has most everything else I need, save for a fuel tank. Most importantly, it has a title. A lot of other stuff to do before I get to it but watch this space.
07-07-2020, 07:20 AM | #2 |
Best of luck with that, Cheesy! I've kind of got an ear to the ground for another frame like that so I can do one of the Harbor Freight engine conversions with a centrifugal clutch setup. I think the missus may be less than pleased if I bring another project home before I have both of the old Hondas up and running. The CB is close; the engine is back in the frame and runs. I just have to route everything back along the frame spine and button it up. Then go get tires and tubes and a few other odds and sods. In any event, please keep us posted with your build. I'm really looking forward to following your progress!
07-07-2020, 07:37 AM | #3 |
That right there is what we call in the construction business a project with potential, lots of potential. And potential cost a lot of money. It will be interesting that's for sure. Sub
07-07-2020, 04:40 PM | #6 |
It's been done before. You might get some ideas from this video.
07-07-2020, 06:41 PM | #7 | |
Jerry-Thanks for the video.
07-07-2020, 09:40 PM | #9 |
Appreciate the offer but I am not in a big hurry for a trans right now. Too much other crap to do. I snagged the Suzuki because I subscribe to ‘He who hesitates is lost’ while Mrs. C is “Good things come to those who wait”.
07-07-2020, 10:23 PM | #10 |
Here are two other videos that are pretty close to what you're planning:
07-08-2020, 07:24 AM | #11 |
So here’s the haul. Frame w/lower half of engine-trans, fork, two front wheels, one rear, and seat. No tank, lights, gauges, harness, controls, rear brake pedal. A project no matter what.
07-08-2020, 02:36 PM | #13 |
You might be able to use the Suzuki bottom end, sans crank for your transmission, it'd just be a bit of welding some aluminum, and connecting the engine to the primary. You could try those aluminum brazing rods that I've seen. It might be easier than you think!
07-08-2020, 04:32 PM | #14 | |
That is another possibility. Would probably need a jackshaft but won't know until I dig into it. And I do have a TIG welder.
