Old 07-06-2019, 09:01 PM   #16
Originally Posted by NzBrakelathes View Post
BUT as far as kick starting and most running goes all 3 are pretty much the same or a very minor change.
I would disagree with this. Kick starting with the pumper carb is much easier thanks to that little squirt of fuel. You basically prime the motor before ever turning it over by twisting the throttle once or twice. Easy way to basically get an instant fire on the first kick.
Old 07-06-2019, 09:15 PM   #17
duck9191   duck9191 is offline
Well the storm is fixed. Got the new voltage regulator/rectifier today and that solved it. It actually charges a bit high now lol. It stays right about 15.2v now at the battery. Only cost me $9, didn't feel like going though the warranty route and having to wait so I grabbed one off amazon.
Tried to put my pumper carb on, but it's not pumping... If you manually move the plunger full travel it will squirt gas, but the action of the cam will not do anything. But thats another thread lol.
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 07-06-2019, 09:41 PM   #18
15.2? That's very high. Is that at 5krpm?
As for the pumper not "pumping" That should be easy to solve. If you want to put it in an appropriate thread my PZ30B Pumper thread would be a great place to discuss the issue.
Old 07-06-2019, 10:20 PM   #19
NzBrakelathes's Avatar
Fair call - I was meaning excluding that aspect.
A pumper or non stock carb is the same inside the slide area and jetting etc.
No reason a stock carb can't easily be kick started with choke and correctly jetted/tuned etc.
Yes I see the point of the extra squirt of fuel.
My bad....
Old 07-06-2019, 10:26 PM   #20
Couple things/suggestions:
Maybe tune carb with stock cable first to get jetting right or close before adding pumper in the mix.
Second thing is the cables tend to float above the carb and not seated in the tube/nibe, push it down and cable tie the cable to the frame so the outer cable doesn't move down into the carb part as you throttle on.
Old 07-06-2019, 10:38 PM   #21
Cravin01   Cravin01 is offline
Cravin01's Avatar
My bad....
I also disagree, I think there have been threads here where people couldn't kickstart their bikes.
The stock carb on my Storm(set properly) would not hardly kickstart, if at all. the pumper does, I have been riding dirt bikes since the 80's and all of them had kickstart with no starters and no issues starting. This is the first bike I could not consistently start kicking it.
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 07-06-2019, 10:43 PM   #22
Stayed at about 15.2 from idle up, was done dealing with it for the night but tomorrow I'm going to check it with the headlight on and see if a load brings it down some.
Old 07-06-2019, 11:45 PM   #23
I almost wonder if the sense circuit (aka signal wire) is disconnected or otherwise shorted? That might explain why your last one died so quickly. It is the black wire on the reg/rec connector.
Old 07-07-2019, 01:34 AM   #24
That's the thing, it's in the bike harness but not in the rec/reg's plug on either. Just green, pink, yellow and red. Maybe they are using the red load line as the reference.
File Type: jpg Screenshot_20190707-013141_Amazon Shopping.jpg (85.6 KB, 94 views)
Old 07-07-2019, 03:52 AM   #25
Nah, the red wire is just an output wire. They likely don't use a signal wire because the output is low enough that it isn't needed, or so much power is drawn from the system that it never reaches a high charge rate (low beam always on, etc).
Old 07-07-2019, 05:59 AM   #26
pete   pete is offline
pete's Avatar
A lot of bikes with kick and electric start are like this..
kick starters are so low geared they don't turn the motor fast enough for long enough...
Even my Yamaha's are a bastard to kick till the motor is hot...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 07-07-2019, 10:08 PM   #27
Hey Dan, do you think this trail tech would work? Adjustable output looks promising, don't really need the time delay power source since the storm has a key.
Trail Tech (7004-RR150) Regulator/Rectifier for DC Electrical System https://www.amazon.com/dp/B00JGRATRM..._DCPiDbH2BRCMD
Still getting 15v with the headlight on, that will eventually boil the battery on a long enough ride so that's better than it not charging but not good. Going to message the seller but I doubt they know a damn thing about the items they are selling and will be of no help.
Old 07-08-2019, 01:27 AM   #28
I might have a solution......
Old 07-08-2019, 10:50 AM   #29
I ain't familiar with that unit. Nothing says it won't work, but I would personally just try a 5 wire unit that has the signal wire on it.
Old 07-08-2019, 12:09 PM   #30
15v at high RPM is fine
My old bike went to 16v some
My RX3 does 15.2v with lights on
Features & details
150 watt full wave regulator/rectifier for DC electrical systems
Built in relay activates switched 12V DC output line only when engine is running, with adjustable shut-off delay, wire connection for use with most machines
DC stator and battery/capacitor sold separately
Trail Tech's Regulator/Rectifier will not work with most factory stators
Stator must have a floated ground, modifications to stator may be required
