05-31-2019, 10:32 PM | #1 |
New Hawk 250 issue
Hi all! I am new to the forum. I apologize if this question has been asked before but I looked around and I didnt find a satisfactory answer.
So I got the bike yesterday and got it fully assembled (Yay!) When I started it up it started to smoke from the front end (from my research this sounds normal). I finally got the bike to idle at half choke, but I can not for the life of me get it to idle with the choke out. I took it for a spin and tried after that and still no luck. As soon as I put the choke out it dies instantly. I tried adjusting the idle speed to no avail. Is this a carburetor issue or something else? I noticed when I was riding it rode fairly rough. Thanks in advance for the help! I have a new carburetor on standby if that is the issue. I am definitely a noob when it comes to this kind of stuff. |
05-31-2019, 11:07 PM | #2 |
I am no expert like these other guys. Probably carb. If you have a mikuni or can adjust the stocker then I bet it will solve your probs. Mine barely ran without the choke at 1/2 when I got it. I rejetted and adjusted idle mixture and it purrs like a kitten.
06-01-2019, 12:29 AM | #3 |
You need to adjust the valve lash if you haven't done so already, and then you will definitely need to dial in the carb tune by rejetting the stock carb or swapping to a Mikuni.
06-01-2019, 01:14 AM | #4 |
Thanks guys! update I swapped to a Mikuni and rejetted to a 110. On a positive note the idle is great and it has more power. But I rode it around for a little bit and as soon as I put the choke out it died. I couldn't even keep it running by giving it gas. I am not familiar with a valve lash Ill have to look into it.
06-01-2019, 01:20 AM | #5 |
You have to check the valves, and remember that engine is a four stroke, find top dead center....etc. There is a lot of info on this site as how to accomplish. It is not difficult, just walk thru it. You can do it!
06-01-2019, 01:33 AM | #6 | |
06-03-2019, 10:33 PM | #7 | |
Still having run half choke with your Mikuni 110 main seems odd though. Maybe mixture screw adjustment? |
06-04-2019, 03:17 AM | #8 |
you use the term "choke out"... usually means the choke is on..
a hot motor normally will not idle with the choke on.. ..
06-04-2019, 10:19 AM | #9 |
Have you looked at the option to tune the carb? That’s pretty much a “must do” in most cases and advisable etc
If you look at my eBay store in the link below you will find somethings that are well worth considering. What’s the other carb you have on hand? |
06-04-2019, 01:14 PM | #11 |
These engine loosen up after about 500-600 miles and will get smoother and shift easier.
carburetor, hawk 250, not running |
