Amazon oil cooler
Does this look like the correct cooler for the Hawk? It says it’s 65 ml. Thanks for the help!
http://KIMISS Motorcycle Engine Oil ..._cC04CbN757C6C |
#2 | |
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
Link doesn't work for me either.
#6 | |
Is there a height difference in the intake and outgoing port? How is flow created? I find it hard to believe that these actually do anything without circulation...
Lots of guys here run them. They are a draw theough system via the oil pump.
Thanks Wild Dog for correcting the link! That was very kind.
I appreciate your knowledge too Megadan. Thanks again, you’ve helped me more times than you know. |
That's the one I'm using with an extra cooler.
It’s the same one I’m running as well.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
If you are ok with waiting for it from China you can get and 85ml for $50 or the 65ml one for a few bucks more from here: https://www.aliexpress.com/item/Moto...e-90e61e9e5bbc
#14 |
I guess I need a "for dummies" explanation of the install. When you say your feeding from the bottom, do you mean the cooler or the engine? Your oil screen hose is on the bottom of the cooler, so if you were feeding to the cooler, then the particulates it catches seems like they would just fall back down the hose to the engine when it was shut off. I don't understand the relationship of top feed vs bottom. Liquids always find their own level, so it seems when the bike was shut off, the oil in the hoses would always run back down to the oil level in the block and leave a little bit trapped in the cooler itself so you would always be starting the engine with a bit of air in the system unless you put check valves on both hoses when the cooler is mounted anywhere above the engine. Help fix my ignorance ![]() |
