Old 04-21-2019, 04:26 PM   #1
MrDeeds262   MrDeeds262 is offline
Crying Help! Hawk down, I say again, Hawk Down
All the wonderful smart knowledgeable peeps on this site please lend me your guidance. I’ve had the Hawk250 for about 6 months. I’ve done all the mods that you guys have posted and what not. I’ve got right at 5500 miles on her and until now nothing has went wrong. I’ve changed my oil every 300-500 miles. Used the good stuff. I’ve stayed on top of loose nuts and bolts. So when I went to change my oil this time m, holy cow you’d think the challenger took off inside there (bad joke sorry). There’s a good 3-4 oz of metal shavings and the only sign I have is I had a squealing type sound when under load without clutch pulled. It would go away in neutral or with clutch in. I’ve pulled the valve cover, the clutch cover the clutch basket, the starter and I’m currently peeping at the cylider walls and head of piston and still see nothing out of place. I will upload as many pics as I can. Any advice is much appreciated!!! Ohh and I’ve contacted Q9 where I purchased and the way to call back at normal bizz hours. Thing is that it’s my daily driver. My only wheels. Gotta get her right ASAP. Thanks again
File Type: jpg 3E983AD5-EB9C-401D-93B6-045F98A8D517.jpg (20.2 KB, 330 views)
File Type: jpg 5AFEC9AD-5FC7-4163-8AF6-48A2BDD363FE.jpg (20.6 KB, 348 views)
File Type: jpg B20FC82C-C96C-43C8-8112-2F336A4429CA.jpg (17.1 KB, 336 views)
Old 04-21-2019, 04:40 PM   #2
Also, there doesn’t seem to be hardly any shaving last in the bottom end. They must have all gotten flushed in the oil or?? There was quite a bit under the shift fork....
Old 04-21-2019, 07:04 PM   #3
Cmon, anybody even have a guess? I have to ride into work in the am, so I’m sitting here hovering over this forum and studying blueprints and schematics so as to hopefully figure out what appearently I’m missing.
Old 04-21-2019, 07:11 PM   #4
MAT   MAT is offline
MAT's Avatar
Aluminium or steel shavings?
Piranha P190R mini-motard racer
20 Thumpstar TSX-190
12 Yamaha TTR-125 FT/ice racer
09 KTM 450 XC-F SM racer
75 CB400F Vintage rider
Old 04-21-2019, 07:27 PM   #5
If I had to guess I would say a bearing on one of the transmission shafts gave out. More specifically I would say on the countershaft.
Old 04-21-2019, 07:34 PM   #6
pete   pete is offline
pete's Avatar
wow....
looks like the machining process is still going on..
you won't know for sure till you pull it a part...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-21-2019, 07:55 PM   #7
It’s steel. And I only have the bottom end left to look. Thanks for the response I was starting to feel a little ashamed / embarrassed. I will know for sure in an hour or so
Old 04-21-2019, 08:58 PM   #8
roundhouse   roundhouse is offline
roundhouse's Avatar
Every time I change my oil I get several little pics of aluminum but never steel.
Check the throw out bearing. I bet you that is it.
Old 04-21-2019, 09:00 PM   #9
sometimes stuff just fails for no reason. im with megadan i think it is in the tranny area
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 04-21-2019, 09:01 PM   #10
me thinks you may need to call a friend ....for a ride to work!
2016 hawk
kaw h1 400 tripple
Old 04-22-2019, 02:36 AM   #11
Well it’s been 12 hrs I have it in pieces and I don’t see any thing that could come close to creating that much metal. Do you think I could have dropped a bit or bolt or something doing valves or perhaps through the intake? I know it’s unlikely but I’m boggled. At least I had a reason to call in for at least a half day tomorrow. Hope something either shows itself cause I’m reluctant to go ahead and put it back together with out confirmation. Thanks everyone I appreciate your help!!
Old 04-22-2019, 02:48 AM   #12
pete's Avatar
noise goes with the clutch in.... that puts it in the gear box..
noise goes in neutral... that puts it in the out put shaft
out put shaft is the only part of the motor not turning in neutral...
I would guess the … out put shaft , gears on it , selector forks on those gears..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 04-22-2019, 03:55 AM   #13
Kivi   Kivi is offline
Gears!
Old 04-22-2019, 04:12 AM   #14
Ariel Red Hunter's Avatar
Transmission bearing breaking up? Dont forget to clean out the centrifugal oil cleaner. Output shaft wiggly? Definatly bearing in the trans...ARH
Old 04-22-2019, 04:38 AM   #15
pete's Avatar
I have never seen a bearing chip like that if it is steel as you say...
I am wondering if it is the dogs on one of the gears...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
