02-05-2019, 07:42 AM | #1 |
New Hellcat gas gauge stuck help.
Good morning guys, first post
I just got a new Hellcat and unboxed it. I'm having a few issues that I could use some help with. The main issue I cant figure out is my gas gauge is stuck on E wont move, I checked the float it moves properly, wiring is all connected I'm at a loss. Wont idle without some choke even when warm and surges badly over 5k I'm replacing carb with a vm22 this weekend hope that's all that is.what size jets have you guys had luck with? So I have a starting point. And had high crank pressure the crank vent was routed to the air box and not letting air through so I unplugged it and put a filter in it seems good now Love the bike just a couple things I could use help with before its road worthy. |
02-05-2019, 07:57 AM | #2 |
Use an ohms meter to check the sending unit and make sure it is working. If that checks out then it's possible the gauge is bad. More than likely its a bad sending unit.
02-05-2019, 08:24 AM | #3 |
The sending unit is part of the float assembly on the hellcat right? What reading should I be getting? Checking at the connector?
02-05-2019, 08:39 AM | #4 |
These are what the Hawk sending unit readings are. Fuel tank full, 09.0 Fuel tank empty, 96.6. Should be close to those same readings. on the Hellcat. Yes, check it at the connector.
02-05-2019, 09:13 AM | #5 |
If you bought the hellcat new, call up the dealership you bought it from. There should be a warranty for like 3 months. Get that issue fixed now before you have to pay to fix it yourself and figure out what's wrong.
But... sounds like the float system isn't sending a signal to the gauge or... the gauge is not working. One of the 2. |
02-05-2019, 09:41 AM | #6 |
Thank you guys for the help, I bought it from Familygokarts I send them an email Friday and a call no response yet and im still waiting on registration.
Little concerned as the breather hose causing pressure and the fact it wont idle on top of the gas gauge is troubling I expected a problem or 2 but seems like allot I did change out the engine bolts and locktited everything just ready to ride it but cant really hoping the carb fixes the ride ability issues. |
02-05-2019, 09:55 AM | #7 | |
The carb issue is more than likely that the carb is tuned to lean at idle. The idle mixture can be adjusted once you remove the taper proof cap over the mixture screw. This is common with most of the china bikes. The new carb will probably resolve those issue as you will be able to tune it without having to hack into the carb.
02-05-2019, 10:05 AM | #8 |
I'm hoping they do, putting the carb on tommarow
Where have you guys relocated they line that goes into intake as the new pipe dosent have a spot for it. |
02-06-2019, 11:32 AM | #9 |
Went through it last night on 3/4 of a tank had 2.0omh at the connector drained some gas and it dropped to 1.7ohm as I pulled a little out. seems to be reading checked the connector its pinned right. Im at a loss.
02-06-2019, 11:41 AM | #10 |
I would go through all the connectors and make sure pins are pushed all the way in and locked in place.
02-06-2019, 01:09 PM | #11 | |
t |
02-10-2019, 07:51 PM | #12 |
I had similar issue's like your having. The gauge was a wire that was plugged into its connector but wasn't making a good connection. High /no idle, bad running
Was a carb jetting / turning problem.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
02-10-2019, 09:36 PM | #13 |
Carb was the issue, VM22 fixed the issue completely. Still tracking down the gas gauge issue, checked every connection no luck.
