Old 11-29-2018, 01:25 AM   #316
NzBrakelathes's Avatar
Originally Posted by rjmorel View Post
So I'm finally getting around to installing the 300 kit bought several months back. Question I have is can it be installed with motor in frame? Do you have to loosen engine mounting bolts and tip it down to get top end off? They really had to cram stuff in there to get all the technology to work.
I miss my Hodaka.
Also I did a compression test on it cold after sitting for a week with throttle help wide open. Only got 100psi out of it . I think it should be closer to 125-135 to run good. Mine has always ran good but didn't seem to have the power of other RX3s on the trips when I've rode with them.
thanks rj
It will just work if you ONLY remove the frame part around the engine - no need to remove the engine.
Stick tongue out to the left to get the top of the motor off
Old 11-29-2018, 01:27 AM   #317
Can do JUST!
Old 11-29-2018, 02:02 AM   #318
sqwert   sqwert is offline
Yes, the 300 kit can be installed with the engine in the frame. NzB's pic is a lot more stripped than necessary. Getting too the engine was more time consuming than installing the kit. The actual engine work was simple.
Old 11-29-2018, 10:10 AM   #319
Agreed. Very easy mechanics. The toughest part about installing mine was the three very curious neighbors leaning in real close with beer breath. ;-)
rj, I JUST got enough room to install it in the frame and had it dangling by the rear mount.
NZ, unless I blew past it, what happened with the new stepper motor? That's my only complaint is that mine is still stalling. It's like a curse....
Old 11-29-2018, 10:36 AM   #320
Juanro   Juanro is offline
Juanro's Avatar
I'm about to help a friend to do a top end job in his bike. We're going to try to do it with the engine in frame.
The part about removing the subframe is clear.
When you say "rear mount" is that the rear swingarm axle? Or the two mounting of the engine to the frame just below it?
Regards
Juanro
Old 11-29-2018, 02:21 PM   #321
Regards
Juanro
Swingarm. It was just dangling there. I removed every mount but that one.
Old 11-29-2018, 07:37 PM   #322
CLEAN the throttle body and focus on the stepper motor passage.
Gently wire brush the crud of the stepper motor nose, brake clean and cotton wool down in the hole where the passages and stepper motor nose meet/meter etc.
Steppers are fairly common and TMAP sensors too for not working correctly.
Old 11-29-2018, 07:39 PM   #323
Regards
Juanro
I left the swing arm bolt in place - the top of the rocker hat will just come out with a twist and a lean to one side and JUST get it out no issue
Old 11-29-2018, 07:59 PM   #324
Regards
Juanro
Oh I forgot to ask, need any parts? PM me
Old 11-29-2018, 09:12 PM   #325
Originally Posted by Spanner View Post
I've read through this entire thread and I'm confused. Has anyone here successfully purchased one of these from this website?
If you want I kit I have them here ready to ship, if you paid today you will have it in the USA mid late next week, $250 all in and free extra's not offered by others.
Old 11-29-2018, 11:48 PM   #326
calvarez   calvarez is offline
Yeah, I got mine from him and would recommend it. All the parts and gaskets you will need. And none of the insanity of that Taobao site.
Old 11-30-2018, 12:45 AM   #327
remember "The personal touch" I delivered to our secret meeting location in the Bronx of L.A lol!
Old 11-30-2018, 09:37 AM   #328
Hey now, I thought that was "our" secret...
Old 12-01-2018, 05:53 PM   #329
+1
Yes, that's a big +1. NzB sends all the parts you'll need and then some. Great value you don't get elsewhere. You buy from NzB you will not have to order other parts.
Old 12-01-2018, 05:54 PM   #330
Please keep it that way.
