Old 09-03-2018, 12:03 AM   #1
akatsuki   akatsuki is offline
Boom 125: To vm22 carb during break-in periods?
I just currently got my Boom125-15, i just ran it 100miles.
My question is.. is it ok to swap the carb during break in periods?
is it better or should i wait it out?
Thanks 🙏
Old 09-03-2018, 03:53 PM   #2
Chinabike   Chinabike is offline
Thanks 🙏
swap it!
Old 09-04-2018, 08:07 PM   #3
I agree with Chinabike it's okay to go ahead and swap it, but even if you don't, I'd make it a point to pull the plug and check it , it's pretty common for the card air/fuel mixture to be set super lean , and it makes the motor run on the hot side - if it shows signs of lean adjust the air /fuel mix screw out 1/2 a turn . ,these little motors already have to work hard no sense running em lean and making extra heat for no real benefit.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-04-2018, 08:27 PM   #4
But he won't be able to adjust the air/fuel on the stock carb. sealed.
Old 09-07-2018, 01:35 PM   #5
Thanks guys! i went ahead and changed the carburetor and man it now runs so amooth, dialed in the mixture just right i guess i have yet to check plugs. but it looks and feels promising.
Difference in speed noticeable, i am now topping out at 60mph with a 17t sprocket..
i am now noticing a stable rpm. before it gets high when heating up.
just a concern: my bile idles high when on a stand tilted, and normal when it is upright. is that normal?
Old 09-07-2018, 03:11 PM   #6
cbrfxr67   cbrfxr67 is offline
cbrfxr67's Avatar
Any pics? What else you going to do to it?
BD125-15
Old 09-07-2018, 03:34 PM   #7
Maybe throttle cable is a little short? does it do rev when you just turn the handlebars?
