01-31-2007, 02:58 PM | #1 |
Help
time for first real oil change . So here is queston were is the oil filter or what pass as a filter?We have ohv 200 motor
thank you & love from the big island[/b] |
01-31-2007, 03:01 PM | #2 |
Take off the oil cap and there will be a small mesh drainer thing right inside there. To my knowledge, no oil filter like a car or anything, but don't quote me.
Roketa DB-07A 200cc |
01-31-2007, 03:17 PM | #3 |
Pull the oil drain plug (big chrome nut on bottom left side of engine, near the shifter). Behind that is a spring that will more then likely fall out. That spring holds in a cone shaped screen. Remove the screen, flush it out, reinstall screen, spring, nut. Fill with 1 quart of oil. Fire it up and drive!
01-31-2007, 03:21 PM | #4 |
thank you
Thanks for the help. I feel better now.
01-31-2007, 03:52 PM | #5 |
If you need some pics there were some post here a while ago.
http://www.chinariders.net/modules.p...ght=oil+screen |
01-31-2007, 07:01 PM | #6 |
oil
Thank you all. I put new oil in the 2 bikes befor we ever road them.But pulled the bottom plug and never looked at the other plug/ filter.
01-31-2007, 10:17 PM | #7 |
got it done!!!!!!!!!!!!!!!
Well did the first service on the two bikes, Oil, valve ajust, welded up every thing we broke. and set to start all over againe.
