Old 01-30-2018, 06:47 PM   #1
Lit Hawk   Lit Hawk is offline
Lit Hawk's Avatar
Hawk locking up
So I’m stuck at work idk what’s wrong with my bike. When I start it I can hear something rattling inside. It started with my chain becoming really loose when I was leaving work. So I came back really slow and it kept locked no up on me in first even in neutral if I roll it a bit it’ll lock up. Almost like whatever’s rattling around is freezing something up for a bit. Any help is much appreciated.
Old 01-31-2018, 12:28 AM   #2
does it lock up with the clutch pulled in?
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 01-31-2018, 12:33 AM   #3
rjmorel   rjmorel is offline
rjmorel's Avatar
I've had a gravel rock get thrown up in chain and sprocket or behind foot brake and lock things up. Look for simple things first. rj
Live Zong, and Prosper
Old 01-31-2018, 01:10 AM   #4
Lit Hawk's Avatar
It’s definitely in the engine, I’m guessing something to do with clutch. Not sure though, I’m gonna dig in tomorrow hopefully and it does sound like somethings broke or loose just rattling around.
Old 01-31-2018, 01:12 AM   #5
Lit Hawk's Avatar
Yeah it would lock up with the clutch pulled in. I would have to rock it a couple times and it would eventually start rolling.
Old 01-31-2018, 09:22 AM   #6
Have you pulled the chain cover to see if the chain is binding or hitting the motor housing? As rjmorel stated , it could be a rock jammed in there.
2020 Kawasaki Vulcan S
Old 01-31-2018, 10:14 AM   #7
Lit Hawk's Avatar
Yes I pulled the chain cover off, there’s nothing in there jamming it. If I start the bike I can hear it rattling around and if I rev the engine it’ll rattle around more. It’s something broke off or came loose inside rattling around. I can put it in first and get rolling but it’ll lock up for a second like whatever’s in there is jamming it up. I only did this twice, I’m now scared to start it because I don’t want to make it worse.
Old 01-31-2018, 10:35 AM   #8
If it is locking up with the clutch pulled that tells me something broke off and in now in the transmission area jamming the gears. You will need to split the case and inspect and clean out. It could be something simple as the end of the dip stick breaking off and falling into the transmission. That happen to someone else on here but don't remember who.
Do you think you may have dropped something in there when you replace the head gasket?
Old 01-31-2018, 10:39 AM   #9
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
Is the clutch cable tension okay? Does it make the noise in neutral with the clutch pulled?
If the controls seem sound it's possible something may have broken in the clutch, possibly a spring or a disk.
If you think that's the case, you'll need to drain the oil and pull the side cover, but try and rule out everything simple first.
Old 01-31-2018, 10:41 AM   #10
On that note, I'm gonna trim the end of the dipstick off, since I only use the sight glass anyway.
Old 01-31-2018, 01:30 PM   #11
pistolclass's Avatar
Are you missing a watch or socket? Friend was telling me a story about a missing socket prior to a jet engine test. They had to disassemble the engine prior to the test. Now all their tools have rf tags on them.
Old 01-31-2018, 06:23 PM   #12
Lit Hawk's Avatar
I’m absolutely sure I didn’t drop anything in the engine. So it just drained my oil and this tooth came out not sure what it goes too. So what y’all think it’s from? What side of the engine should I open up? Do you thinkit would be ok to drive like this? It seemed to want to run fine it’s just this tooth was locking something up.
File Type: jpg F49C44B2-AA93-4783-B691-189C095F0FEF.jpg (20.1 KB, 423 views)
Old 01-31-2018, 06:41 PM   #13
Lit Hawk's Avatar
Damn just pulled 3 more teeth out of oil drain hole.
Old 01-31-2018, 06:54 PM   #14
You could ride it like that, but be prepared for potential catastrophe if that gear sheds more teeth. I would personally put the bike down and start taking it apart until you identify where those teeth came from. Luckily even the transmission gear sets are pretty cheap for these engines, so it shouldn't cost too much to fix. Just time.
Edit. If your bike is still under an engine warranty you might consider contacting the dealer you bought it from.
Old 02-01-2018, 08:09 AM   #15
I wouldn't drive it and risk doing farther damage. Hopefully there is no damage to the case from the gears jamming. As MD states the transmission gear set are cheap. I would tear it down and see what the damage is.
