Old 02-12-2008, 12:27 AM   #16
bronevaya   bronevaya is offline
TA-DA!!
well I fixed her!!
let me explain
this model shineray I have has a dual exhaust setup, when I lost one of the mufflers I plugged the end with a pipecap (it was under the faring so you cant tell it had dual exhaust)
As it so happens the remaining muffler's metal mesh (on the inside) came loose and wadded up the inside of the muffler. I pulled it out and there I had it, the bike now runs normal!!
Thank you guys so much for your input and willingness to help, my car is in the shop so I am ecstatic that I can now get places without the need to bug my friends and co workers 8)
Old 02-12-2008, 09:29 AM   #17
Guest
Posts: n/a
congrats!
Old 02-14-2008, 04:14 PM   #18
liverchip   liverchip is offline
Send a message via MSN to liverchip
Can you post photos of the exhaust setup?
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 03-13-2008, 02:15 PM   #19
oh nooo, it came back. its not as bad as before, but it is pretty bad, adjusting the A/F mixture does very little to help.
sorry about not getting a pic, Ill try and get one soon. I dont have internet at home yet.
Old 03-13-2008, 07:29 PM   #20
I'm telling ya; check fuel flow from the tank and check the coil 12v connection. I've experienced both.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 03-15-2008, 12:44 PM   #21
KW4TX   KW4TX is offline
Man I have having same issue...
My biggest problem is the ratio screw is at the very bottom of carb... and I have about a inch and a half to try to get a flat head screwdriver on it.. :(
So I will either use the screwdriver bit from an interchangeable screwdriver (which I have been doing)..and try to get it lined up and get my hand in a un human direction and try to adjust the screw...
OR: take carb off and on every time I adjust...
Got idling and starting good but it bogs and is unridable
Already fouled one plug dealing with the darn thing
Old 03-15-2008, 01:02 PM   #22
AZ200cc   AZ200cc is offline
I took a cheap little pocket screwdriver and bent it into a 90 Degree cheap screwdriver They also sell a very short 90 driver with a phillips on one side and a standard on the other.
http://www.dm-tools.co.uk/product.ph...n//sn/DRA12412
Most parts houses have them.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 03-15-2008, 01:14 PM   #23
pacman   pacman is offline
Originally Posted by bronevaya
this model shineray I have has a dual exhaust setup, when I lost one of the mufflers I ...
How did you loose one of the mufflers? Did it break off?
Old 03-15-2008, 03:02 PM   #24
Guest
Posts: n/a
KW...wrap the bottom end of one of those removable screw driver bits with electrical tape. I made a mini-screwdriver that way. BUT it is still a real hassle.
Old 03-15-2008, 03:15 PM   #25
kczukiman   kczukiman is offline
[quote="KW4TX"]Man I have having same issue...
What works good for me is a long set of forceps/hemostats
http://www.harborfreight.com/cpi/cta...emnumber=94952
Old 03-18-2008, 12:56 PM   #26
I noticed that I dont have a petcock filter, so how would I check fuel flow?
and 12v coil? where do I look for that?
Old 03-18-2008, 05:24 PM   #27
knothead   knothead is offline
1. Shut the fuel off at the petcock, remove the line and slowly open the petcock. Gas should run out. Do the same on both the "run" and "reserve" positions.
If gas comes out, check the line from the tank to the carb.
2. Follow the plug wire. One end is stuck on the plug, the other end goes to the coil.
Old 03-21-2008, 01:56 PM   #28
a while back when I drained fuel from the bottom of the carb we noticed that it wasnt flowing out, sort of just trickling out. could that be a problem?
Old 03-21-2008, 02:13 PM   #29
NewEnglandTrails   NewEnglandTrails is offline
Sputtering..
I had sputtering that went away when I adjusted the clip on the needle. Carbs can be tempermental depending on your height above sea level.. and what height above sea level the bike was manufactured at. If the sputtering problem is coming back, do an onsite search for adjusting the carb needle.. Its really easy.
With regards to your fuel flow... it wouldnt be the first time the chinese left some debris in the tank that could block flow... try cleaning your tank and lines as well..
NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD
Old 03-27-2008, 12:57 PM   #30
its me, bronevaya, the author of this thread.
I fixed it.
it was a large pain in the ass, taking the carb off the bike. but it paid off. I still have stuttering (sometimes), but thats because of the exhaust.
also, factory, the needle clip was set at the very top, moving it to the bottom I can now start it without choke.
p.s, I did all the work on the bike outside my apartment complex, at night, with a flashlight in my mouth. all of my neighbors probably think I am an expert mechanic
