05-23-2017, 01:15 AM | #1 |
Hawk dyno.
I am entertaining the idea of doing a pre and post mod dyno run with my Hawk as I live a couple of miles away from a shop with a dyno.. Just curious if anybody has any opinions on how I should go about this. Its 55 bucks to do a baseline run with O2 readings, so obviously I don't want to do 10 runs successively. All runs will be done with corrected results since they will likely be on different days.
For baseline I had 1 of 3 ideas. Looking for opinions. Either: 1. Straight out of the box as it comes. Or 2. Straight out of the box, but with stock carb jetted properly, but no other mods. Or 3. Mikuni carb jetted for an otherwise stock bike. Modified run. I am willing to do this in 2 stages. Just trying to decide how to stage them out. Or, simply do all of the typical mods in one go and see what the difference is. I am more keen on just doing all of the mods in one shot, but a part of me is curious on what just the exhaust does on its own. I did also pick up a new head assembly to port for down the road, and that will likely be combined with a larger carb setup. But, for now, I am interested in opinions on how to do either stage, and try to get kind of the popular opinion of starting point and finishing point. Feel free to chime in with whatever you feel. The idea is to post the results in this thread at a later time.
05-23-2017, 01:48 AM | #2 |
start with a standard motor / pipe / carb jetted correctly & running as good as it can
as the factory intended but feel short of.... then if you can each mod on it's own then combined... .
05-23-2017, 01:55 AM | #3 | |
I would be interested to see the comparison between a stock filter with the airbox mod, and a stock airbox with a k&n panel filter though, and then obviously both. Then all of the above combined with stock vs aftermarket exhaust. However, thats where the dyno time can get expensive for me. Having to swap parts on a hot engine back and forth doesn't appeal to me a whole lot. That is why I am trying to find a logical progression of mods that most owners would do. IE, exhaust, then intake. That said, I may be willing to do a side by side between a modded airbox with k&n vs. A pod uni filter. I think that would answer qurstions for many owners.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 05-23-2017 at 03:28 AM. |
05-23-2017, 02:28 AM | #4 |
Sounds like you would be doing a service to the hawk owners who want more power squeezed out of their bikes ,it might be possible to have some of them pitch in for some dyno time since it will ultimately help them as well .
05-23-2017, 03:17 AM | #5 |
This satisfies my own curiosity already, and I don't want or expect any sort of compensation. I am a curious kind of person, so i would be doing this anyway.
05-23-2017, 06:49 AM | #6 |
At minimum, dyno results from out of the box. Then with the normal mods most of us do; carb, exhaust, air box mod, spark plug. Those two runs on the dyno would be awesome!
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
05-23-2017, 08:09 AM | #7 |
I had planned on doing the same when I got my Hawk. A friend of mines had a dyno in his shop that I had access to anytime I wanted to. He had closed down shop and sold everything the week I got my bike so it never got done. My plan was to dyno completely stock out the box then do one mod at a time. 1st mod would be stock carb with jet. 2nd remove cat and rejet. 3rd would of an adjustable CDI and finding the right timing for maximum performance. Only problem with that one was the only adjustable CDI I could find only changed when the timing advanced and couldn't adjust the actual timing itself. I would really like to see how much more HP we can get out of theses bikes. When ever I do the EFI on conversion I will be able to change timing.
05-23-2017, 10:20 AM | #8 |
Dump testing
I'm with Sir Kayakalot.
An "out-of-the-box" as a base line, just so we know where we start at. Then a typical modded Hawk (air box mod, carb with jets, spark plug and exhaust). Now, if you wanted to do one other run, between those two, how about all the mods but with a stock (gutted cat) exhaust. That will help people decide if they want to add the exhaust system. Keep us posted!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
05-23-2017, 10:25 AM | #9 |
Gutted Stock exhaust vs After Market and the stock carb vs Mikuni
05-23-2017, 03:07 PM | #10 |
Personally, I think the aftermarket exhaust on an otherwise stock Hawk would probably give similar results to a modified exhaust. Maybe its a little better, but having seen the ebay exhaust for myself, aside from the straight through muffler on the end, I honestly don't think there would be much difference between that header pipe and a decatted stock one. If there is, it would be fractions of a horsepower.
As far as stock carb vs. the VM26 Mikuni. Personally, given the similar specs and layout of the two carbs, I don't think there is any performance gain between the two. The main advantage of the VM26 is that it is far easier to setup thanks to the availability of jets. That said, A comparison between the traditional VM26 and a 30mm flat slide PWK/KOSO or Mikuni would be interesting. I just don't happen to have one of those on hand. As far as the baseline. My only problem with out of the box with zero carb tuning is that it's essentially not as it should be. That is why I like Pete's idea for an otherwise stock bike with the carb jetted properly. I think that is a fair baseline to start with. It won't take much for me to toss a 105 main into the stock carb. Just keep in mind guys, while I would love to spend the time to do every little bit, this isn't a free endeavor for me. $55 each set of runs out of my own pocket here. While doing 2 or 3 runs is reasonable, 10 of them will cost half the price of the bike. That is why I think a properly jetted stock bike vs. a completely modified bike comparison would be a great comparison. With maybe an exhaust only run tossed in, and only because I believe the stock exhaust is the most restrictive part of the bike.
05-23-2017, 04:20 PM | #11 | |
05-23-2017, 10:51 PM | #12 | |
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
05-24-2017, 01:01 AM | #13 | |
05-24-2017, 05:11 AM | #14 |
I will only say that the K&N filter should be dry and not sprayed. You also need to seal it under the retaining bracket. Roger also didn't talk about carb adjustments.
05-24-2017, 01:50 PM | #15 |
If it gives the same dyno results as the Qlink XF/XP 200, expect about 5 hp increase.
It started at 15 hp and after jetting and a different muffler, it dyno'd at 20 hp. That's a substantial increase percentage-wise. I can't find the original post but here's the vid for proof. http://chinariders.net/showthread.ph...highlight=dyno I have not seen anyone do this with a Hondoid. It will be cool, megadan.
