Old 05-12-2017, 06:57 PM   #16
I flipped the bracket and rerouted the hoses. It really tucks it up nice and tight under the plastic. Hoses look better too. And fixed the brake line retainer for JeremC
2020 Kawasaki Vulcan S
Old 05-12-2017, 09:27 PM   #17
goat67   goat67 is offline
goat67's Avatar
Looks real good. I think I will order one also.
2016 Brozz
Old 05-13-2017, 01:24 AM   #18
JeremyC   JeremyC is offline
LOL! That retainer looks great now! I do really like the oil cooler setup.
Old 05-13-2017, 10:19 AM   #19
mjstef   mjstef is offline
Just an FYI, Flat stock will move it toward the engine another inch. Where you able to grind the crimp off and cut the hose? Can't tell....
Old 05-13-2017, 10:32 AM   #20
Maybe my just woke up brain is confused. Trying to say you have a kit or two without lines? If so... How YOU doin!
I have 4 valve cover style kits here with black valve covers and black stacked plate coolers with guard. (stock photo shows aluminum) My wholesale cost is $55.50. Throw $10 for shipping on them for a total of $65.50 and i will ship them Monday. No 10-15 day wait lol. E-mail me @ hwakclusters@gmail.com I really don't think i'll be able to offer a competitive kit as all forms of BULK shipping are absurd out of Chonqing. Cheaper 1 at a time with China Post. Have a great weekend folks!
Old 05-13-2017, 12:08 PM   #21
I didn't have to cut the line. I was able to route the lines to take up the extra slack. Using the 1" angle it gave me more clearance for the oil lines and I was able to mount the cooler higher up under the tank plastic. The 1" angle was stiff enough that I didn't have to use a top mount bolt. I knew that 1" crating angle the Hawk came in would come in handy for something.
Old 05-15-2017, 12:23 AM   #22
check all connections on it every now and then. i had a small leak i was going to address this evening but about half way back home turned into a big blowing leak. one of the banjo bolts on the valve cover had loosened up from the vibration. made a hell of a mess.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 05-15-2017, 01:02 AM   #23
Oil resistant loctite 243 is your friend. Clean the threads with brake cleaner and use a bit of that. Give it time to cure before filling with oil and running it and you shouldn't have an issue.
Old 05-15-2017, 07:50 AM   #24
Thanks for the heads up. I took about a 60 mile trip on Saturday and check it all over when I got back. Nothing loose and I put another 98 miles yesterday. all still snugged up with no leaks. I always have a habit of checking the bike over before trips and after.
Old 05-15-2017, 12:17 PM   #25
[QUOTE=Megadan;255850]Oil resistant loctite 243 is your friend. Clean the threads with brake cleaner and use a bit of that. Give it time to cure before filling with oil and running it and you shouldn't have an issue.[ i was thinking because of the heat it wouldnt help much.
2016 hawk
kaw h1 400 tripple
Old 05-15-2017, 02:23 PM   #26
It's rated up to 360 degrees F operating conditions, and while engines get hot, if your oil and engine case are ever that hot, you have other issues to consider.
Old 05-16-2017, 12:27 PM   #27
I've only researched the valve cover style that Matt offers, not the drain screen cap style. China Riders, please share opinions about which style you'd prefer and why. I would think that just for ease of oil changes, the valve cover style would be a benefit. Also, with the cooler mounted vertically, would everybody route oil out of the engine into the top of the cooler (like a conventional radiator) and then out of the bottom and into the engine? What about if it is mounted horizontally?
Jerry, your installation looks terrific! Very tidy.
Old 05-16-2017, 01:12 PM   #28
I would prefer the oil screen cap style, but only because it cools the entire flow of oil to the motor down. That said, the valve cover style may only cool the oil going to the head, but that oil is going directly to the head and valves. On an aircooled engine, that's the right place for it to go.
Personally, I think the screen cap system should have a slightly larger heat exchanger given that it is handling the entire system capacity. Wider and taller, and I would mount it horizontally if I could. Since it is horizontal and the front fender may cause airflow issues, the larger cooler could also allow for a small fan and a thermostatic switch, if necessary (hot climate). Have I ever mentioned that I tend to like overkill?
As far as flow direction, i would prefer horizontal. In a vertical application, I would feed top and flow out the bottom.
Old 05-16-2017, 01:18 PM   #29
Thanks, I went with the drain screen cap because I liked the idea because I know all the oil is being pumped through the cooler. I wasn't too sure on how much of the oil is passing through the valve cover style. Matt offers both styles and his kits do have the stack plate coolers but he was still waiting on shipment of the new kit. I wanted to have mine install before I took it on my trip this past weekend so impatient me I ordered the one I have. I think Matt has a better cooler and will order a stack plate cooler later on. As far as oil change I drain from the plug on the bottom anyway. The screen inline is easy to remove and clean. I have mine feeding from the bottom and out the top so I have no problems purging the air out the system after an oil change and no need for a check valve as the oil doesn't drain back into the block. Being it's so small I don't think it will make a difference. I tried mounting it horizontally but the fender block most of the air flow to the cooler. I had put a 1" plastic spacer between the fender which dropped the fender and had enough clearance. Personally either cooler is better than no cooler. Over the weekend I put close to 160 miles on it in mid 90's heat. Cooler defiantly working as you can feel the heat dissipating off the cooler. I thought about mounting a couple of small e-fans for when off road trail riding when you know your going to slow to cool it off. I put e-fans on my turbo intercooler for drag racing to cool it down while lining up for the next race.
Old 05-16-2017, 01:37 PM   #30
So I'm not the only one? Better have it and not need than to need it and not have it.
