Old 04-23-2017, 03:38 PM   #16
Azhule   Azhule is offline
Did you make sure the exhaust header nuts/bolts have enough torque on them? Don't remember exactly but it was over 10 or 12 ft lbs to seal that pipe up to the engine
Might have a leaky exhaust header gasket? Easy and cheap to fix that, get a Copper Crush Gasket from Honda
Or you might have the valves set on the wrong 'TDC' ?
Old 04-23-2017, 03:59 PM   #17
Ariel Red Hunter's Avatar
Originally Posted by rwl6935 View Post
Well the heat shield and cat weren't causing the noise, it's definitely piston slap. I recorded the sound on my cell phone. I don't know how well it translates, but you can hear the valves which is normal and then when I pick up the rpms you can hear the secondary noise which is the piston slap. Let me know if you can hear it.
http://s859.photobucket.com/user/rwl...74F34.mp4.html
I did hear a thump there which could be piston slap. If it was me, I'd find a long, decent size screwdriver, and test it by listening at various places down the cylinder by sticking the blade between the fins on either the front, back, or drive side of the engine, and sticking the handle end in my ear. After that I would do the crankcase where the main bearings are, and below the cylinder/crank case joint to see if it is the big end. Now you did the valves, right? Was there plenty of oil up there? If not, it could be an oiling problem, which like any of the other things you find are warranty issues. Valves sound awfully loose to me, Should be .002 intake, .004 exhaust, inches. Could be just how you had the mike of the camera...ARH
Old 04-23-2017, 07:36 PM   #18
rwl6935   rwl6935 is offline
rwl6935's Avatar
No, it's there cold or hot. I was hoping that once it warmed up the piston would expand and quite down, but it doesn't.
Old 04-23-2017, 07:39 PM   #19
rwl6935's Avatar
I set the valves to .005 per the manual. It's funny that all these bikes use the same motor but require different valve gap.
Old 04-23-2017, 07:41 PM   #20
rwl6935's Avatar
Oh, so you're saying the copper gasket may be rattling around. I'll check that.
Old 04-23-2017, 07:42 PM   #21
rwl6935's Avatar
Originally Posted by da4design View Post
does the rattle go away after it warms up?
No, same hot or cold.
Old 04-23-2017, 07:44 PM   #22
rwl6935's Avatar
Originally Posted by Ski_rush View Post
Sorry that I don't have an answer, but my bike does not sound like that.
You're lucky! I spend more time fixing sh*t then riding.
Did you ever sell yours?
Old 04-23-2017, 08:53 PM   #23
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
Can you host it anywhere else but photobucket? My browser is choking on the sheer amount of ads and trackers that page tries to serve. Youtube would work.
My motor on my TT250 has a very distinct rattle. I'm told it's fine, it doesn't seem to bother it at all.
Old 04-23-2017, 09:03 PM   #24
It's hard to tell from the video. Almost sounds like an exhaust leak. If you were close by I could check it out.
2020 Kawasaki Vulcan S
Old 04-23-2017, 09:25 PM   #25
rwl6935's Avatar
Probably not going to put it on YouTube.
It's definitely not normal. The thing sounds like there's a bucket of bolts in the cylinder. I sent the seller a lengthy email about the issue. Let's see if I get blown off with these folks... if so, they will lose.
Old 04-23-2017, 09:26 PM   #26
rwl6935's Avatar
Jerry, drive over on the hawk! Haha
Old 04-23-2017, 09:41 PM   #27
MOTOXtreme   MOTOXtreme is offline
Wish there was something I could do to help you. Can't remember what happened with your first hawk but I hope they don't try to pull anything. Almost all these sites offer a "12 month engine warranty".
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 04-23-2017, 09:57 PM   #28
Ski_rush   Ski_rush is offline
It's still available
Old 04-23-2017, 10:08 PM   #29
rwl6935's Avatar
Thanks, brian
I purchased an extended 12 month warranty, but that's only as good as the company backing it. I guess we'll find out Just how good.
Old 11-13-2017, 08:13 PM   #30
vomitis   vomitis is offline
Do you have the counter balanced engine?
