03-03-2017, 12:10 PM | #16 |
Cartridge Emulators
Hey Rail32,
Have you looked into cartridge emulators from racetech.com? They offer Dirt Emulators and they are listed by size. I haven't taken my forks apart yet, so I'm not sure if they have something for our Hawks. In the meantime, I'm going to go with your "new oil and double nickel shim kit"! The "Double Nickel Shim kit"! Am I the first to "coin" that phrase? Sorry, it's Friday and I have worked the last 19 days straight! Have a Great Weekend and see you on the trails, Dan-O
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
03-03-2017, 12:24 PM | #17 | |
03-03-2017, 06:49 PM | #18 |
Hey JerryHawk250,
The alarm is tomorrow's project! I worked the last 19 days straight, so I didn't have any time to work on the Hawk.
03-03-2017, 08:27 PM | #19 | |
Yes I checked woth race tech , th y have nothing that small of dia . It will frighten ya to see how samll the spring is if you are familiar with bikes at all. Progessive dude I need to talk to on vacation till late next week . The phrase is all yours , feel free to " cash " in with it .
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good |
03-03-2017, 08:32 PM | #20 | |
03-03-2017, 08:40 PM | #21 |
They honestly feel pretty sweet. But all I can do is barely get a little air with front end over ditch at my house . We have rough 3" snow on ground and ground under it is pretty soft . I would say I made them %30 better for my weight than orginal. Wanna try 1 more nickel aka shim and see if it gets better or too stiff . My concern is not soaking up little bumps fast enough with too much shims. But for a light 250 cc bike at this point it's very rideable for a 5'8"195 lb 51 year old dude that thinks he's 20 something . Well till I get off it and make those old man sounds my father started making 20 years ago.
I am not sure what that means , so I do not think about that too much .
03-03-2017, 08:46 PM | #22 | |
03-04-2017, 12:44 PM | #23 | |
03-04-2017, 05:29 PM | #24 | |
03-05-2017, 08:38 PM | #25 |
tonight i changed my fork oil 210 in one 200 in the other and grey like said before.No spacers gonna see how she feels.Took her for a quick ride but really need to re jet the carb since i put a K&N filter in.
03-05-2017, 10:52 PM | #26 |
We don't have nickels over here.... So I was forced to bolt a whole YZF250
front end in to my bike... O well thems the brakes.. I will just have to make do...
03-06-2017, 09:08 AM | #27 |
That there be overkill on a china bike.
03-06-2017, 09:21 AM | #28 |
I like the idea of progressive springs...if we know the diameter of the springs and what the maximum diameter the forks can accept, maybe we can find a set that would work?
2002 BMW R1100S, 1999 Kaw Concours, 1991 Kaw Eliminator 250, 1969 Honda Trail 90 Too many damn mopeds... |
03-06-2017, 08:34 PM | #29 |
Use the motorcycle fork size chart to find a similar weight bike with the same size fork tubes. Then search for upgraded springs for that bike. They should work with the China bikes. It may require running spacers. I have used PVC pipe for decades with absolutely no issues. Just use fender washers between the spring and PVC spacers. RaceTech used to publish their spring specs on their website. I have used mostly RaceTech for the past 15 years unless someone requested, or brought me, something different to install.
https://kiwavmotors.com/en/faq/about...ube-size-chart I have used Progressive a couple times. I have a GS500 with them. They are OK but weight matched Racetech springs are way better. It's even better with their emulators and Torco fork fluid. I recommend Torco fork fluid due to their temperature spread. From just below freezing to well over 100*F, Torco fork fluid retains its viscosity and doesn't get thick or thin out with temp change.I use 5 or 7 in sport bikes and 10 in everything else. If 10 feels to soft, the fluid level can be raised about 10mm to help stiffen the fork up. https://www.amazon.com/Torco-T830010...2b649743313e05 |
03-06-2017, 09:33 PM | #30 |
That front tire reminds of the Dunlop 756 that I have on my Kawasaki KX125.
