07-29-2016, 09:40 AM | #1396 |
not really, prob one of the tt's w 15 front sprocket.
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking |
07-29-2016, 10:16 AM | #1397 |
[QUOTE=celswick13;226536]As far as I can tell, the slide on the carb is working fine and the bike is at WOT.
I have not used GPS to verify top speed yet, I will soon. I do know that at up to 40 everything is mostly accurate. I have a tach and register about 8k Rpms at 50. I've seen a top of 8.5k Rpms. I keep hoping I'd find something wrong. I even triple checked the sprockets hoping I misread them. I even plan on double checking my valve adjustment. But so far I haven't found anything wrong. So, time will tell. It runs fine otherwise. My TT has the same problem that is" 8000 rpm at 50mph". I don't have a tachometer but I do know a wound out motor and my bike is WOT at 50mph. It came delivered with 17 50 sprockets so I suspect the primary gearing is wrong on my bike. I did install a 43 tooth rear last night and it made a huge difference in the feel of the bike. 50 is no problem now with plenty left. I will have to ride it more to be convinced of the 43 tooth because now first gear is a little high. |
07-29-2016, 10:53 AM | #1398 | |
These CG motors are very tight when new. I'm thinking give it its 500 miles and then open her up and check it with your GPS. These speedos do run opposite. When it registers 45, you're doing about 50 according to most reports.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 07-29-2016 at 11:44 AM. |
07-29-2016, 11:16 AM | #1399 |
Your going off indicated mph? Who knows? Gps asap just find an app
Not that this is your problem but heavy viscosity oils and over fills can make it fight for rpms. Just like drag in the water.
07-29-2016, 11:17 AM | #1400 |
His original post says he checked sprockets and they are proper... who knows.
"I can't break 50mph unless going downhill. And yes. I have the proper sprockets." |
07-29-2016, 03:52 PM | #1401 |
New TT250 low seat kit! May work on the Hawk too? Seat Concepts makes a nice seat. I love the tall seat on my RX3. Quality stuff.
http://www.cscmotorcycles.com/TT250-...sc-300ttkt.htm
07-29-2016, 04:04 PM | #1402 | |
Previous: '80 KZ550, '04 Shadow 750, '12 NC700X Current: CSC TT250 |
07-29-2016, 06:47 PM | #1403 | |
I'll call csc back at 500 and then 1000. |
07-29-2016, 08:39 PM | #1404 | |
if the speed is accurate, and the sprocket tooth count is accurate, then someone installed the wrong gears in the factory. (or you aren't getting into 5th gear)
07-30-2016, 09:29 AM | #1405 |
well if there are different internal gears available on these we need to get that info asap. cscs hasn't said a thing about swaps for the tranny
07-30-2016, 09:29 AM | #1406 |
07-30-2016, 10:28 AM | #1407 |
Oh gosh, with how these are massively produced, my feeling is I doubt that the Chinese have put much thought into making more than one set of tranny gears for these to assemble as fast as humanly possible. They're great at build/assemble but "options" are not really their gig. It would be interesting to see if there's two sets of clusters for the Zong CG but I highly doubt it. Just a feeling, no fact.
I'm still banking on it's not broke in yet....... These little things develop a ton of heat and friction in their early lives.
07-30-2016, 04:33 PM | #1408 | |
I think it's odd that it would be so "tight" compared to others, unless maybe something was installed wrong or torqued wrong, but I've seen no major signs of anything wrong. Time will tell. I'm installing a trail tech vapor on it right now. |
07-30-2016, 05:03 PM | #1409 |
One of the better upgrades on our Bashan was slapping on a Trail Tech Digital Speedo/Tachometer
07-30-2016, 05:16 PM | #1410 |
Which Trail Tech model did you use?
2016 CSC TT250 |
