Old 06-25-2016, 08:41 PM   #1
faulknja   faulknja is offline
Hawk - Rear Shock
Does anyone know of a heavy duty replacement shock with preload adjustment? The stock one is pretty weak
Old 06-25-2016, 09:01 PM   #2
kohburn   kohburn is offline
kohburn's Avatar
the RX3 shock is being used on the TT250 i believe.
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 06-25-2016, 09:01 PM   #3
pete   pete is offline
pete's Avatar
measure the length eye to eye/fork...
then head for e-bay.....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-28-2016, 01:50 AM   #4
Entropy   Entropy is offline
Please do reply back with your measurements and findings.
Old 06-28-2016, 03:35 AM   #5
humanbeing's Avatar
Stock NXR Bros (& copies) = up Ø10 low Ø10
Old 06-28-2016, 11:36 AM   #6
'16 TT250   '16 TT250 is offline
Once you find one with the correct length, mount style & size, and travel you'll have to figure out spring and damping rates. If the stock shock can be drained and filled you could just play with oil weight.
Old 06-28-2016, 04:22 PM   #7
humanbeing's Avatar
Originally Posted by '16 TT250 View Post
...If the stock shock can be drained and filled you could just play with oil weight.
Change spring
http://www.motorfans.com.cn/forum.ph...d=75082&page=1
Old 06-28-2016, 05:36 PM   #8
Originally Posted by humanbeing View Post
I assumed he's after stiffer damping since he's asking about a heavy duty shock, he also mentions preload adjustment so maybe he's after a stiffer spring...or maybe both...or maybe he doesn't know what he needs to achieve the feel he's after.
Old 06-28-2016, 06:57 PM   #9
Ariel Red Hunter's Avatar
That's neat. It would be even better if I could read it.
Old 06-28-2016, 08:13 PM   #10
Yes, I'm looking for a stiffer spring. Any weight and this thing bottoms out
Old 06-29-2016, 01:44 AM   #11
This is the first I've seen posted about the spring being too soft; unless it's a common problem, or you're heavier than the average rider, maybe you just got a defective one and a stock replacement could fix it. The one human being posted has an adjuster, if yours is the same size you could get one of those. Adjusting isn't the right way to fix a spring being too soft, but it at least it can keep you from bottoming out.
Old 06-29-2016, 04:09 AM   #12
Thumbs Down
I changed out the f/r springs in my main KLR and it made a 'huge' difference (I am heavy) but having some additional dampening wouldn't hurt also. that can be done by rebuiding the shock and using different valving and oil but it's a looong way from easy for the typical rider and probably a waste of money. you should be able to find an inexpensive replacement from another hawk like chinese supplier. I've seen em in the orient carrying a family of four on their bikes, someone HAS to be making what you want. hell the rear on my 200 Zong is so stiff it jars my teeth
Old 07-02-2016, 03:05 AM   #13
humanbeing's Avatar
...Any weight and this thing bottoms out
Maybe similar syrnome as http://www.chinariders.net/showpost....5&postcount=90 (No oil ...bad seal) btw. Beta Alp 200 copy (Loncin, Kinlon...) = http://www.cnabsorber.cn/products_de...uctId=137.html | Honda KRH (NXR bros "KRE" is quite similar)http://www.cnabsorber.cn/products_de...uctId=396.html
Old 07-02-2016, 02:48 PM   #14
I might have found a shock that could work, but I can't figure out how to get the Chuannan Shock Absorber site to tell me the weight of the spring, the eye-to-eye length of the shock, or the size of the mounting holes. The shock number is XY 211.
Old 08-27-2016, 07:40 AM   #15
jimwildman   jimwildman is offline
jimwildman's Avatar
Im looking to lower the rear suspension by one inch, i just hate the way it keeps you up againt the tank, too high in the rear, and i cant slide back when i need to shift my weight to the rear.
i think it looks stupid soo high in the rear anyway,.
I will likely add a second shock mount lower on the swing arm.. also closer to the fulcrum so likely to make the suspension softer by increasing the leverage on the shock. ill need an adjustable shock..
has anyone identified a good or great replacement?
or the stats on the stock shock to help with shopping for one.
