Old 06-11-2016, 03:05 PM   #46
Originally Posted by detours View Post
That's a good price for a full synthetic. I'm curious how 20/50 will work in our bikes. I wonder if the higher viscosity will reduce blow-by in the cylinder. But higher weight will at least help mitigate thinning from fuel in the oil.
As you said, thicker oil, will it increase internal drag on my little bashan and rx3? Make a slow bike slower? But speed in not the point is it? I'm gonna give it a try, it certainly won't hurt it.
Blow by/ fuel thinning remark, makes sense.
Old 06-11-2016, 10:41 PM   #47
Lee R   Lee R is offline
Lee R's Avatar
The sticker on the bikes frame actually says 20w50 oil on it, and 91 octane fuel. I ran some 20w50 valvoline 4T non-synthetic for the past thousand and it did feel smoother shifting. I've got Rotella T6 in it now for newfoundland as it's going to be a high of 60 and possible 30's in the morning so I don't want a thick oil in the bike. The Rotella T6 is working fine, shifting is not quite as good as the heavier oil but still pretty good.
If you having shifting issues check your cable slack first, I've found that most of the time it's that and the cables on this bike seem to stretch a lot.
I've been running 91 octane fuel in this bike from the start because we have non-ethanol fuel here everywhere in upstate NY and it's only in 91. If the bike sits you don't get any issues with non-ethanol and storage.
Old 06-11-2016, 10:56 PM   #48
pete   pete is offline
pete's Avatar
Yer buy a nice new bike then the first thing yer do is try to pinch pennys
in the last place yer should... or use a oil that was never intended for the job...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-12-2016, 09:19 AM   #49
dpl096   dpl096 is offline
dpl096's Avatar
I'm kinda using Joe's Blogs as my guide on giving the Quicksilver a try in my RX3:
April 30th - http://californiascooterco.com/blog/?p=21156
May 7th - http://californiascooterco.com/blog/?p=21317
May 16th - http://californiascooterco.com/blog/?p=21425
Quicksilver 20W-50 Full Syn Motorcycle Oil, 1 gal:
Protects gears, transmission and wet clutch
Meets or exceeds manufacturer's warranty requirements
Meets or exceeds API SF/SG/SJ/SL/SM and JASO MA2
Manufacturer : © 2016 Mercury Marine. All Rights Reserved. Reproduction in whole or in part without permission is prohibited. Mercury Marine is a division of Brunswick Corporation. yeah yeah yeah get over yourself already
Please make your suggestions - all are welcome.
File Type: jpg Motorcycle_compare.png.750x0_q85_crop-scale.jpg (20.8 KB, 221 views)
― Thomas Jefferson
Old 06-12-2016, 11:24 AM   #50
detours   detours is offline
detours's Avatar
Any oil that is JASO MA or JASO MA2 certified, in a weight recommended by CSC and the sticker on the bike is absolutely intended for the RX3.
I'm going to get a gallon Quicksilver 20W-50 and give it a try.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
