06-09-2016, 06:41 PM | #1 |
Burning plastic smell?
Last few days I've noticed a faint burning plastic kinda smell from the bike, I'm at 2000 mi., not sure what it is. Seems to be centered under the gas tank / engine area, not exhaust. It isn't something I'm very worried about because it's nothing crazy strong...but I'll probably take the seat off and poke around this weekend.
On an unrelated note - I skipped the 500 mi valve check...planning to just do it at 2500mi. Have anyones valves ended up not needed adjustment?
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.) '82 Suzuki SP250 (11k Miles) '85 Honda Rebel 250 (Sold April 2016) |
06-09-2016, 07:54 PM | #2 |
Surfndirt - not sure how many miles you have on the bike. If fairly new, it could just be some oils that is burning off. But still worthwhile to check under the seat, just in case whether new or it has a few miles.
First thing I would check is that nothing is coming in contact with the header and mid-pipe. There is a fuel vapor cannister above the mid-pipe (and behind the thick steel frame member on the right side of the bike). Check to make sure that hasn't dropped down and contact the mid pipe. If that's well clear of the the exhaust pipe, then check around the engine for any wires or fuel lines that may be contacting the engine. Hopefully you'll be able to identify, isolate and resolve the problem if something is contacting the engine or exhaust pipe. |
06-10-2016, 12:53 AM | #3 |
On mine I found a venting tube at the bottom of the gas tank running to evaporation canister, kinked and laying on top of the exhaust pipe.
It was burnt, but luckily not completely through Will have to get CSC replace under warranty or if I am nice replace it myself with some car vacuum tubing |
06-10-2016, 09:00 AM | #4 |
When I checked my valves @ 600 miles they were all so tight that I could not get a .04mm feeler between the valve stem and rocker. That seems to be pretty common for the first check. The risk is that clearance will go to zero and you burn the valves or eat up the cam. Good luck.
06-10-2016, 10:24 AM | #5 |
Like others said here, I'd pull the seat and check it out. Lift the tank up too and see if there's anything not in its right place. They jam a ton of hoses and wires under that tank.
I'd check the valves. It seems everyone's have been tight but mine, or those who have posted so far. Three out of four of mine were at .08mm but I'm glad I checked them. I didn't want to eat up the cam.
06-10-2016, 11:10 AM | #6 | |
06-10-2016, 05:40 PM | #7 |
Alright guys, I'll get on that valve adjustmen asap!!
And turns out...that's where my vinyl rain pant went...onto the exhaust header, that's a relief!
06-11-2016, 09:16 AM | #8 |
I'd echo what everyone else said, check those valves. Both my intake valves were very tight at 500 miles. I think you'd risk damage waiting until 2500.
06-11-2016, 09:28 AM | #9 |
Dang, she's been running fine. Just got some stuff I'll need, I'll be doing it tomorrow morning :V
06-11-2016, 09:55 AM | #10 | |
Glad to read that the burning smell was remnant vinyl from another source instead of the bike! |
06-11-2016, 11:29 AM | #11 |
Good luck on the valve adjustment
06-11-2016, 01:42 PM | #12 |
How long has it taken yall first time around? From what I've read, the most time consuming part is taking everything off. A buddy of mine who's a honda/suzuki/kawi dealership mechanic will be supervising me for the adjustment part.
06-11-2016, 10:11 PM | #14 |
LOL!
06-11-2016, 11:08 PM | #15 |
It takes about 3-5 hours for the first check. I take my time and clean up parts under the tank and have a good look around while I've got the panels off.
Honestly the panels come off really quick and easy on this bike, 15 minutes and everything's off and tanks tipped back so the valves are accessible. I don't remove the tank I just rotate it and tip it sideways with everything connected on a towel where the battery is then bungie it down so it doesn't fall off. I spend the majority of the time trying to get feeler gauges into the exhaust valves. I did the second check on mine today, 3000 miles on the bike and all 4 were at .04mm. They were all set at .08mm at 500 miles. I'll be sticking to 2500 mile checks until I see those things settle down, 5000 seems a bit too long. |
