Drop-in 279cc engine for the RX3?
Following some links, I found a 279cc Zongshen engine called the CBS300. It looks a little different than our NC250, but I wonder if it would be a drop in replacement? The oil filler might be under the exhaust, but maybe ...
Here's an image on Facebook that shows the same HP and torque as our 250cc models. https://www.facebook.com/zongshenmot...type=3&theater And a chart on this mychinamoto forum page with pretty much the same numbers. ![]() I wonder why the numbers match our NC250 so closely. Maybe it's just that efficient? Normally a bigger bore improves power, but it all depends on engine design.
Its probably for a much different application. I agree it doesn't make sense. It would be a pointless conversion for an RX3. Probably like Ford (or whomever) using different versions of 4/6/8 cyl engines.
Detours...Weird as I was driving today I was pondering exactly what you posted..what if?
drop it into the TT
Far less work to just install the already existing big bore kit, and see what happens.
I keep changing my mind from BBK to the Turbo as my first major mechanical upgrade. |
I'll have to look for that big bore kit. I've got a spare engine in the garage from my swap and a big bore kit might be the perfect thing to do with it.
Anyone have a link?
#7 | |
what big bore kit?
I think I would rather wait for the RX4 with the 450cc engine, which Zongshen plans to introduce next year.
![]() http://www.chinariders.net/showpost....postcount=4969
The GasGas Cami motor makes 20.6.kW or 28 HP and the bike only weighs 117 kg.
It uses a carb instead of injection. |
#10 | |
if you look at the 250/300 charts though the displacement has less of an effect than the cam - the 250 is cammed for lower end torque - at 4500 rpm it has almost 50% more toque than the 300. the 250 has a much more flat torque curve and the 300 has a much more peaky torque curve.
#11 | |
2016 CSC RX3 Ginger Edition Check out my blog here: https://www.facebook.com/My-CSC-Zong...0302595973417/ |
#13 | |
#14 | |
bet it would make a cheap hawk or bashan scream with a carb set up. (water cooler added of course)
#15 |
Would it really matter what the new bore is vs. the old? When they are giving you a new sleeve, and piston to match? Obviously, if the bolt holes and water passages don't line up, that's an issue.
Would this make it more of a stroker? Maybe what's missing is a longer connecting rod? |
