Old 12-18-2015, 09:12 PM   #1
detours   detours is offline
detours's Avatar
Check your air filter
If you haven't done this yet, check your air filter.
I looked at mine recently and it was almost bone dry. I added some filter oil and it actually quieted the engine down. Probably getting some noise from the intake side.
Here's the CSC tutorial on air filter maintenance:
http://www.cscmotorcycles.com/Articles.asp?ID=254
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 12-18-2015, 10:05 PM   #2
Thanks for posting the reminder.
Indeed, it's important to oil the air filter. A dry air filter will pass dust into the cylinder, and damage the intake valves.
Old 12-18-2015, 10:43 PM   #3
jbfla   jbfla is offline
I checked my air filter when I installed a charging pigtail on the battery.
The filter was dry except for a thin smear of grease (not oil) in the center of the filter.
It seems this should have been checked by CSC during the $195 setup.
jb
2014 XT 250........
Old 12-19-2015, 10:43 AM   #4
Perhaps it's a missed item on their checklist. I recommend that an owner send an email to them, as a friendly reminder.
Old 12-19-2015, 11:36 AM   #5
I don't think the oil filter in my Zongshen ZS200GY-2 (Sierra) was oiled. The last new Japanese bike I bought was a 1979 Honda Hawk II. I don't remember if the manufacturer/dealer oiled the air filter. One of the first things I do when I acquire a bike is inspect, clean, and oil the air filter.
Old 12-19-2015, 12:24 PM   #6
Tiger12XC   Tiger12XC is offline
Tiger12XC's Avatar
Same here on the first oil change I pulled out the filters and not a drop of oil on them.
This is what I used on them:
http://www.cyclegear.com/MAXIMA-FFT-Foam-Filter-Oil
Old 12-19-2015, 01:04 PM   #7
I use BelRay Air Filter Oil for the flat, foam air filters on both my Zongshen bikes.
https://www.rockymountainatvmc.com/p...air+filter+oil
Old 12-19-2015, 02:08 PM   #8
Mudflap   Mudflap is offline
All my China bikes came with a dry air filter from the factory. I use chainsaw bar oil. Thick and sticky, just what you want.
Old 12-19-2015, 03:06 PM   #9
pete   pete is offline
pete's Avatar
i use the castrol spray can stuff...
its green so yer can see if yer missed
any...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-19-2015, 03:41 PM   #10
Danimal   Danimal is offline
Banned
I use Belray air filter oil.
And the Zong Owners Manual funny enough makes no mention of oil as part of maint., just to take the element out and clean the dust out.
Wonder if the factory's tuning and such for EFI took into consideration the additional intake resistance oil in the filter can cause.
Is there a tutorial yet for filter removal? I need to get mine out but it's so damn cold out today...
Old 12-19-2015, 05:09 PM   #11
jb
2014 XT 250........
Old 12-19-2015, 05:56 PM   #12
JB just posted the link for the online tutorial. The CSC Owner's Manual, provided with the bike on DVD, contains the same information on pages 74-75. Both sources state you should oil the air filter.
The foam of the air filter is only a medium to hold the oil. It is the oil which traps the tiny dust particles, and prevents them from joining the fuel/air mixture, and entering the engine. If one doesn't oil the air filter, dust will damage the intake valves and the valve seats, causing valve recession.
The Delphi MT05 ECU and various EFI sensors are constantly working to obtain the perfect, stoichiometric air/fuel ratio of 14.7. The air filter of the RX3 is very large, and is capable of passing more than enough air to support fuel combustion. Therefore, unless you apply an excessive amount of oil, you won't reduce engine performance by oiling the air filter.
Old 12-20-2015, 01:15 PM   #13
Banned
Spud, I fully understand the function of the oil i a foam filter.
The posted .pdf manual I read didn't look like it indicated adding oil. I wasn't stating that as if to say "this foam filter doesn't need oil".
So I looked at my air filter for the first time today. Filthy. But...unlike the others here, mine had been oiled and was still quite tacky even though covered in dust and dirt.
Cleaned and reoiled.
Two other things I noticed, and they were the first "substandard" things I have seen on my Roxer
One of the 5 screws holding the cover down was missing. You can tell it was never installed. (the one hardest to get to.)
And...the oring in my cover on that same lower corner was installed all twisted.
And...one of the four remaining screws was nearly stripped already by the factory.
twisted o ring in cover
nearly stripped screwhead
Old 12-20-2015, 03:03 PM   #14
The posted .pdf manual I read didn't look like it indicated adding oil. I wasn't stating that as if to say "this foam filter doesn't need oil"...
I never said you didn't understand. I was just stating general principles of oil filter maintenance. We have a lot of people on these forums who are unfamiliar with some areas of motorcycle maintenance.
Old 12-20-2015, 05:42 PM   #15
Banned
just didn't want you thinking I was proposing to anyone that they not oil their filter
