08-24-2015, 01:53 AM | #16 |
I must admit, I can't believe Honda is recommending 8,000 miles as an oil change interval. The engine in my Zongshen RX3 is very similiar, and has a capacity of 1.7 quarts of oil. Yet Zongshen recommends an oil change every 2,500 miles.
08-24-2015, 03:29 AM | #17 |
A lot of work for a small amount of oil......
08-24-2015, 09:53 AM | #18 |
I really like the CRF. Seems like a good bike at a fair price and the ergos fit me well.
I'm seeing holdovers in my area at a good discount but I don't have the scratch to get one.
Current: bikeless for now, moved into a campervan. Past: 2012 Honda NC700x, 2014 Taotao ATM-50-A1, 2014 Taotao Evo, 19?? Honda Spree 50, 1982 Katana 550 |
08-24-2015, 11:07 AM | #19 |
I agree with Spud and Pete. I would target about 20 hours for an oil change, not 80 hours. BTW, that's with a liquid cooled bike that has a filtered crankcase vent. On a more primitive air cooled bike (like all of my junk), I target 10 hours.
08-24-2015, 05:36 PM | #20 | |
this windshield is almost half the price of the on I ordered but holes must be drilled in the fairing to support it and the fairing is the only thing that supports it. |
08-24-2015, 05:44 PM | #21 |
The brush guards came in from Amazon today so I installed them before work. These are generic brush guards and don't seem to be the best quality buy not the worst. I really don't have anything to compare them to. I put brush guards on my will but they were cheap mostly cosmetic ones of all plastic construction an only 1 support from handle bars. These from amazon are aluminum with the plastic molded around them into 1 piece. The clamps mounting them the handle bars are adequate but the bar end inserts would not expand enough to go tight. The finish on the plastic is not as nice as I would like it to be but they will do for as long as the hold up. If and when it comes time to replace them I will go with something different.
08-24-2015, 05:47 PM | #22 | |
08-24-2015, 11:55 PM | #23 |
If you switch to aluminum bars, the inserts will probably be tight enough. Aluminum bars typically have a smaller ID, since they need to be thicker than steel bars.
08-25-2015, 05:41 PM | #24 | |
The big reason for the 8000 km oil change interval is the fact that a lot of new vehicles nowadays come straight out of the factory with synthetic oil in them. Which allows for much longer intervals. Im sure you are correct on finding a used one Andy i have already seen a few on Kijiji for 3K and less. And Yea you are probably correct on the hand guards Weld.
Past bikes: '10 Gio X33 '85 Honda VF750F Interceptor '80 Honda XL185S '76 Yamaha DT250C dual sport Baja Wilderness Trail 250 '07 Honda Shadow 750 Areo Trike '01 Harley Davidson Softail Deuce Polaris Magnum 425 4x4 Quote:
08-25-2015, 09:39 PM | #25 | |
I'm gonna stick with the stock bars for now. I may have to locktite on the handguards. the clamp bolts on the right came loose after 65 miles. I may be able to tack weld some nuts with a similar diameter to the inside of the bar ends to have something to bolt to. |
08-28-2015, 07:27 PM | #26 |
CeRF's windshield came in today (I named the beast CeRF, I know I don't get any point for originality there.) The windshield is nicely made and went on in about 15 minutes with absolutely no alignment issues. Its bigger than I thought it would be. It does a great job deflecting the wind around me. I'm not sure that I like the way that it looks on CeRF, but it works.
08-28-2015, 07:58 PM | #27 |
Those windshields have a good reputation for being well designed, and working well.
08-28-2015, 08:14 PM | #28 |
Looks good dude.
" If it ain't broke, I can probably still fix it!" ---- Tim Allen |
08-28-2015, 08:23 PM | #29 |
Thanks, I'd like to see some more pics of you bike, I"ll have 585 miles on CeRF when I get home tonight, time for the 600 mile oil change. Its starting to break in and finding first is getting easier. still getting used to the gearing much tighter than Wills.
08-28-2015, 09:10 PM | #30 |
I'm considering ordering a 3.1 gallon aftermarket fuel tank. I can't make up my mind. Its a little over a gallon bigger then the factory tank. I'm currently getting between 52 and 78 mpg. On the highway its been between 52 and 55 and putting around the back roads and on the trails I got 78 mpg. The cheapest I have found a tank (natural color) is $209, that's a lot of money just to not have to fill up as often.
