Old 09-01-2010, 03:53 PM   #16
Originally Posted by bennell
if you are planning on braking down the forks dude, any chance of pics that i could use to change my seals
Yes, I certainly will take photos. If you have a Zongshen 200GY-2, or one of the Qingqi/QLink bikes that employs USD forks, you can learn a lot by referring to the Brazilian, Qingqi Service Manual. Although this manual is written in Portuguese, it is still easy to understand. You can obtain the Brazilian Service Manual at the following link.
http://www.mychinamoto.com/downloads...Portuguese.pdf
The USD fork information begins in Section 15 of this service manual.
Old 09-02-2010, 05:44 PM   #17
bennell   bennell is offline
cheers spud, ive got the manual which in some text is ok to translate but google doesnt do it perfectly and im a picture learner when you get pics ill use the manual with them to get my seals done
Old 08-05-2015, 02:40 PM   #18
hect75   hect75 is offline
hect75's Avatar
Hola Spud, I need to service my vento´s fork. According to your post the songzhen uses an oil seal 30x50x11 mm. I searched on skf but the stores only have 30x50x10mm and wonder if I could use this size.
Gracias
Hector
Mountrack Vento 2006
Old 08-05-2015, 08:55 PM   #19
Gracias
I suggest you use the fork oil seals for the 2009 Honda CRF150R, as I mentioned in the following thread.
http://www.chinariders.net/showthread.php?t=10266
Old 08-05-2015, 10:55 PM   #20
humanbeing's Avatar
One of them:
http://articulo.mercadolibre.com.mx/...nda-suzuki-_JM
Old 08-06-2015, 01:37 AM   #21
hect75's Avatar
Originally Posted by humanbeing View Post
Gracias humanbeing, I will stop by some shops first before ordering these ones. i don´t know why I was thinking 30x50x11 instead of 37x50x11.
Hector
Old 08-06-2015, 01:40 AM   #22
hect75's Avatar
Gracias Spud, I stop by honda store long time ago. They´re very expensive for me. I will try in another motorcycle shops or the web.
Hector
Old 08-06-2015, 01:53 AM   #23
You're welcome. Initially, I didn't catch your mistake on the size. Here are some links to eBay vendors for the correct, fork oil seal.
http://www.ebay.com/itm/37-50-11mm-A...56b194&vxp=mtr
http://www.ebay.com/itm/New-Motor-Fr...37da66&vxp=mtr
http://www.ebay.com/itm/Fork-Oil-Sea...1798e8&vxp=mtr
Old 08-06-2015, 06:27 AM   #24
humanbeing's Avatar
... stop by honda store long time ago. They´re very expensive for me. I will try in another motorcycle shops or the web.
Bearing shop is the way to go.
btw. Suzi GZ150 http://www.suzuki.com.mx/motos/gz150-15 also use that "37-50-11"
Old 08-14-2015, 12:18 AM   #25
hect75's Avatar
Hola, I service the forks with the oil seal size recomended by spud and humanbeing. I used REPSOL 10W. The bike improved and rides better than the old and leaking oil seals. I am confused with the black smoke coming from the exhaust (the outlet and right turning light are black) and white plug. According to the experts, black smoke means rich mixture and white plug lean mixture. I am using mikuni 120 and needle carb on 4th notch. I know 120 is very small but I found the 137.5 and the bike does not run beyond 70 km. Using the 120 the bike reaches 100 km. I will buy the jets ASAP to fix the problem but could someone explain why white plug and black smoke?
Gracias
Hector
Old 08-14-2015, 02:34 PM   #26
When are you actually seeing black smoke? Only at idle, or also at wide open throttle?
Old 08-16-2015, 02:22 AM   #27
hect75's Avatar
In fact, I can´t see the smoke only build up at the exhaust´s outlet and turning light. i shortened the exhaust 1.5 inches to avoid smoke build up.
Hector
Old 08-16-2015, 12:40 PM   #28
I recommend a plug chop at cruising speed.
