#31 | ||
![]() Quote:
http://www.nsifleet.com/pdf/ProgrammableSpeedometer.pdf http://www.springfieldstreetrod.com/...ionsSpeedo.htm
#32 |
I remained convinced that it must be calibratable. I'm hopeful that the talented people here will sort it out.
#33 |
I'm almost inclined to 'bite the bullet,' and get the SpeedoDRD.
#34 |
Try turing the key on but not starting the engine, then hold individual and combinations of buttons. I had a compass you had to hold the button down, then power up.
"Thou shall not Zong" is not a commandment. |
#35 |
I have an ideal on a "fix" for this, when I finally get around to trying it out, I'll post back results....
should change from 14% high to about 5% low...so it would read about 53 mph when you were actually doing 55 mph, opposed to the current "reading 62 mph when you are actually doing 55 mph"
#36 |
Thanks for the input, but I think I have tried every possible combination of pressing buttons, both while starting the speedometer, and after the speedometer is running. I have performed all these experiments while the engine was not running.
#37 | |
#38 |
I'm pretty sure the RX3 employs a 3-wire, Hall Effect sensor. The SpeedoDRD receives this signal, then modifies the output rate to the speedometer, as shown below.
![]() If someone knows of a microchip which performs a stepdown function of about 10 percent, we can build our own speedometer calibration unit. ![]() ![]()
#39 |
For example, here is a speedometer calibrator design which employs a $20 microchip, which can be programmed on your computer.
http://members.rennlist.com/tom86951...r%20Page1.html ![]() ![]() http://rennlist.com/forums/944-turbo...alibrator.html
#40 |
Sending PM......
#41 |
#42 |
speedo
Huck,if you figure it out ,even for just the stock ture size ,I want To purchase one,I really want to know how fat I'm actually going!
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
#43 |
I already know how fat I'm going. Too fat.
#44 |
Fat
good one weld !!! My laptop is down,, so hitting the buttons on my phone is tuff,, They're small!!
#45 |
Been there, done fat.
