04-10-2015, 10:41 AM | #1 |
Zongshen ZS200 GY oil seals
I have a Zongshen ZS 200 GY 2 and I want to get oil seals for the gear lever, kickstart lever and sprocket spline.
Do you know the sizes or codes for these please? |
04-10-2015, 12:04 PM | #2 |
Welcome!
They're likely the same as a Honda XR200, but you'd need to check the seal markings to be sure. Instead, I take the markings from the seal and buy them at a local bearing shop. Much cheaper, and they're usually in stock.
04-10-2015, 11:17 PM | #3 |
Your Zongshen ZS200GY-2 uses the same engine parts as the currently manufactured, Yamaha TW200 motorcycle.
The oil seal for the shift shaft is part #7 in the following diagram. This oil seal is Yamaha part #93102-12321-00. The oil seal for the countershaft is part #23 in the following diagram. This oil seal is Yamaha part #93102-22389-00. The oil seal for the kick start lever is part #10 in the following diagram. This oil seal is Yamaha part #93102-17263-00.
04-11-2015, 04:17 AM | #4 |
Measure them... go to somewhere that sells seals/bearings etc...
None of the bike makers make there own seals/bearings they buy them just like you can...
04-11-2015, 11:16 AM | #5 |
Apologies... I failed to notice that you said ZS200 GY2; I was thinking of a Honda clone, and not a Yamaha clone. Please follow Spud's guidance if you want to use Yamaha parts.
You can still get the seals at a local bearing shop if you choose.
04-13-2015, 03:56 AM | #6 | |
Hi All,
Thanks so much for the help, managed to sort it out Quote:
